Thread: Now, Decisions on a Sub |
Silver Member Username: Tycoonbob
Ky
Post Number: 189 Registered: May-07
| Posted on Friday, May 16, 2008 - 02:40 pm: |
So car situation is pretty much taken care of, but now subbage. Im thinking maybe 1 15" or 2 12". which do you think would be better? im not looking for amazing SQ or anything, and i will prolly be running around 1200-1500rms. reasonable budget, nothing outrageous. dont want to spend no more than 500 on subs, but would perfer to stay in the range of like 250-350ish. but here is what im currently looking at: TC [Audiopulse] Revo [1 15"] RE Audio MX [1 15"] RE Audio SE [2 12"] Digital Design 3515 [1 15"] DC Sounds Level 4 [1 15"] Fi.Q [1 12"] Fi.Q [1 15"] Soundsplinter Rl-S12 [1 12"] Soundsplinter RL-P12 [2 12"] Audioque SDC2.5 [2 12"] Audioque HDC3 [1 15"] Audioque HDC3 [2 12"] {Maybe} So I'm not limiting myself to that, thats just what im kinda currently looking at. I want it to sound clean, lows arnt ultra important to me [I listen to rock/alt/metal...double bass =)] and want it to be loud. Would like the box to stay at or under 3cu. ft. I have an idea of pricing on these subs, but not exact. If you could help me find something that I would like, and im not all that picky. Personally I think my 2 10" Type-S I put in a little junker sounds great. That's how simple I am. Yeah. So any reason I should count one of those out? or is there something better in my price range? Also, ported or sealed boxes? Those Type-S sound great in sealed, and the box isnt big at all...and I like that. But how would the sub sound different in a sealed vs. ported. I know each sub is different =/ Thanks though. |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 524 Registered: Sep-07
| Posted on Friday, May 16, 2008 - 03:31 pm: |
Lots of good choice ( i would toss out the Q since you say lows arent important) I'd also say get the 15" AQ HDC or Revo Go ported unless space is an issue |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5879 Registered: Feb-06
| Posted on Friday, May 16, 2008 - 05:30 pm: |
I would do an RL-S 15". |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1540 Registered: May-07
| Posted on Friday, May 16, 2008 - 06:22 pm: |
Never heard any AQ subs, but I would scratch them if SQ is your goal. Actually I haven't heard any of the subs in person on this list lol. I have heard some good things about the SE's sealed and the RL-S's are suppose to be awesome. Maybe a a single spider RD alpha? 1 old SI mag or 2 new ones. RD classics SSA Icon (suppose to play similar to the Q) |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 948 Registered: Aug-07
| Posted on Friday, May 16, 2008 - 06:37 pm: |
RL-s 15" x2!!! IT will R@PE the lows! |
