Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > 12 cubes..what would u do???
Author Thread: 12 cubes..what would u do???
Username: Gula187
Baton Rouge, Louisiana
Post Number: 115
I have 12 cuft to work with in the back of an 75 caprice
what would you do sub wise
Username: Kyle_lowe
Post Number: 937
two of these
http://www.soundsplinter.com/rlp18_subwoofer_information.html
Username: Charlesbhs
Dallas, Tx
Post Number: 578
i'd say you get 2 15" RL-S... im pretty sure you'd be more then happy with those.. ;) just make sure you get a good/big amp to power them.
http://www.soundsplinter.com/rls15_subwoofer_information.html
Username: Nd4spd18
Northwest PA
Post Number: 7504
Well what are we looking for here.
For SQ, charles's suggestion. For SQL, Kyle's. For SPL, two DD 9518
Username: 04redmach1
Columbus, GA
Post Number: 1911
2 Heavyweight 15's on a 3250.1 a piece
Kevin
PS: Depends on your goals too though :-)
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5877
Two 15" Audiopulse LMS Ultras on a Zapco C2K 4kw a piece
You'll accomplish any goal you were setting out for with that.
Username: Drant19
DUB-C, TX
Post Number: 949
lmao reece!
Tony, how about you give us your budget for subs and amp!
p.s. you will need a HO alt to run more than 1500rms, just throwing that out there
Username: Gula187
Post Number: 116
$1000 amps
$2000 subs
Username: Gula187
Post Number: 117
$1000 amps
$2000 subs
= daily ground pounder
Username: Jkidder
Worlds gunna end, In
2012
Post Number: 3550
i'd do 1500 on subs and 1500 on amps. have you also put aside mone for a new alternator, multiple batteries and wiring?
my suggestion would be..
6 new SI MAG 12's (2.0 cubes a piece)
3 Kicker SX1250's (feeding each 600 plus watts)
the cisco kid
Username: Rovin
1 15 = 149.1DBs
Trinidad & T...
Post Number: 13756
gotta consider sub & port displacement so id do either 4 12s or 2 15s ...
Username: Jkidder
2012
Post Number: 3551
oh i'd go sealed with the above setup. another thing im not sure if the 12's come in d4 as well as d2. if only d2 it wouldnt work with those amps
Username: Jkidder
2012
Post Number: 3552
the cisco kid
Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > 12 cubes..what would u do??? [ « Previous ] [ Next » ]
