Thread: Need pair of 10 or 12 subs for 140 shipped fast!!!!! |
Silver Member Username: Mike_16
Reedsburg,
Wisconsin
Us
Post Number: 911 Registered: Aug-06
| Posted on Friday, May 16, 2008 - 11:14 am: |
anyone got any good deals or know wear to get some decent subs for this price |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 945 Registered: Aug-07
| Posted on Friday, May 16, 2008 - 12:36 pm: |
ebay is your friend. you can probably find like some kicker cvrs, or some pioneers ts-w307s, or alpine type-s. do you already have an amp? |
Silver Member Username: Dirtrider125
Post Number: 146 Registered: Apr-07
| Posted on Friday, May 16, 2008 - 01:04 pm: |
u can definately get some 12" cvrs for that on ebay |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7503 Registered: Jul-06
| Posted on Friday, May 16, 2008 - 03:39 pm: |
Yea I think CVRs are the best good subs you're gonna get for that price. Also a pair of Audioque SD2 would be $200....... |
Reedsburg,
Wisconsin
Us
Post Number: 913 Registered: Aug-06
| Posted on Friday, May 16, 2008 - 08:28 pm: |
yes i only have 150 to work with. yea i found 2 12 cvr for 99 and 45 shipped ... but and the alpine s for like 160 shipped. but ill check those pioneers . thanx |
Post Number: 150 Registered: Apr-07
| Posted on Friday, May 16, 2008 - 10:48 pm: |
on onlinecarstereo.com u can get 2 alpine type s for 160 shipped i would do that |
Reedsburg,
Wisconsin
Us
Post Number: 915 Registered: Aug-06
| Posted on Saturday, May 17, 2008 - 11:59 am: |
would the s's be better than the kicker cvr? if so ill do it i just never heard them b4 |
Reedsburg,
Wisconsin
Us
Post Number: 916 Registered: Aug-06
| Posted on Saturday, May 17, 2008 - 12:08 pm: |
ok i cannot find 2 12inch alpine s dual 4 ohms on ebay or at onlinecarstereo.com either..i found dual 2 ohm and 10 inch but i want 12" . can you link me the page for that if u can? |
Platinum Member Username: Rovin
1 15 = 149.1DBs Trinidad & T...
Post Number: 13760 Registered: Jul-05
| Posted on Saturday, May 17, 2008 - 12:12 pm: |
i would go with the cvr - they sound pretty good ..... |
Reedsburg,
Wisconsin
Us
Post Number: 917 Registered: Aug-06
| Posted on Saturday, May 17, 2008 - 12:18 pm: |
ok i found 2 12' s's for 160 and dual 4 ohm .. ok now i just dont kno wwitch to get and i am ordering them in a few hours. so im not sure i had teh old kicker vr 10'' and they pounded but i have never heard the new s yet only a old one . so i need advive witch sub guys ??? |
Post Number: 152 Registered: Apr-07
| Posted on Saturday, May 17, 2008 - 02:17 pm: |
the alpine sounds better and will be just as loud in a good ported box |
DUB-C,
TX
Post Number: 952 Registered: Aug-07
| Posted on Saturday, May 17, 2008 - 03:23 pm: |
^^^fail kicker cvrs would be louder than alpine type-s's. and as far as them sounding better, they will sound good as long as you put them in the correct enclosure. a good install can go a long way |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 528 Registered: Sep-07
| Posted on Saturday, May 17, 2008 - 05:09 pm: |
^x2 Type-E and Type-S are less than ideal woofers, which has always seemed strange considering how good the Type-R and Type-X woofers are... |
Reedsburg,
Wisconsin
Us
Post Number: 921 Registered: Aug-06
| Posted on Sunday, May 18, 2008 - 05:15 pm: |
ok so ill be going kicker i guess! |
