Thread: JVC KD-G700 REMOTE ISSUE |
New member Username: Vanhager
Post Number: 1 Registered: May-08
| Posted on Wednesday, May 14, 2008 - 08:02 pm: |
My remote suddenly stopped working. My friend gave me his and it doesn't work either.Is there some way to drain the memory from the head unit or remote...I know this has to be done with some remotes or units to get them to work again. Thanks........ |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1216 Registered: May-07
| Posted on Thursday, May 15, 2008 - 12:38 am: |
does your face plate flip down? if so check contacts, you could have one not making connection. about the remote thing and memory these radios are not like that. u could of also had the electric sensor eye it break connection from road vibration but i think a contact is just bent. |
Post Number: 2 Registered: May-08
| Posted on Saturday, May 17, 2008 - 08:51 pm: |
Faceplate pops right out...contacts all look good |
Old Bridge,
NJ
USA !
Post Number: 1242 Registered: May-07
| Posted on Sunday, May 18, 2008 - 04:01 am: |
sometime the contacts may look fine but arent mathing up make sure thier all the same heght and nice and straight. |
