Thread: How much power can my alternator handle? |
Bronze Member Username: Weezer4rock
Post Number: 12 Registered: Dec-07
| Posted on Wednesday, May 14, 2008 - 06:44 pm: |
I've got a 2000 Civic with an alternator rated at 75 amps. How much amplifier power do you think my alternator can handle safely? |
Relevant Product Info
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16605 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 09:16 pm: |
75 amps isn't much. Top of my head I would say 750w and below? Other informed members will chime in. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7454 Registered: Jul-06
| Posted on Thursday, May 15, 2008 - 03:10 am: |
Thats a good estimate Paul. |
Post Number: 13 Registered: Dec-07
| Posted on Thursday, May 15, 2008 - 11:02 am: |
do you mean rms? |
Northwest PA
Post Number: 7466 Registered: Jul-06
| Posted on Thursday, May 15, 2008 - 12:42 pm: |
Yes always measure wattage in RMS never peak, it is useless. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1578 Registered: Mar-04
| Posted on Friday, May 23, 2008 - 11:06 am: |
it depends. There is plenty of anecdotal evidence that a 60A alt can sufficiently power a 1000w rms system, but others have had trouble with a lot less. Personally - I had a car with a 75A alt. A lot of enthusiast owners of that particular car believed the alt was undersized W/O any aftermarket electronics. Regardless, I went ahead and installed a 1000w+ system. It wasn't ideal, but it ran ok for 2 yrs or so. |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 8098 Registered: Jul-06
| Posted on Wednesday, May 28, 2008 - 02:31 pm: |
Efficiency of your amplifiers plays a huge role in what your alternator will support wattage wise. You might have 2 different amps that produce 1,000 watts RMS but one only uses 50 amps for example versus 100 amps. |
