Thread: HELP ME PLEASE |
New member Username: Fearfactory
Albany Australia
Post Number: 1 Registered: May-08
| Posted on Wednesday, May 14, 2008 - 12:45 pm: |
I have 2 rockford fosgate subs on a brain vibrations 1000w amp all is good but i just bought 2 pioneer 800w subs and a kenwood 1800w amp which i wish to use instead of the other amp, but i would like to know can i hook all subs to the one amp, i have looked at the wiring ports at the back of both amps the brain vibrations one has 4 outputs but the kenwood one only has 2 so yeah can i hook them all up to the one 1800w amp its a class D mono block. Any help would be great but please talk to me as if i am stupid cause i dont know what all this RMS and 2.366 stuff means Cheers to you all from the land down under |
Relevant Product Info
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 921 Registered: Aug-07
| Posted on Wednesday, May 14, 2008 - 01:32 pm: |
dont mix subs. stick to either pair on a amp. |
New member Username: Weezer4rock
Post Number: 7 Registered: Dec-07
| Posted on Wednesday, May 14, 2008 - 02:37 pm: |
I agree with Abarca. Also, you could over excert your amp and blow it if you try to hook them both up. Essentially that would be wiring them parrallel which reduces resistence and the amp may not be able to handle that small of a load! |
Albany Australia
Post Number: 2 Registered: May-08
| Posted on Wednesday, May 14, 2008 - 02:53 pm: |
hey cheers to you all so more questions wat if i were to have all the same subs could i then put them on the one amp or should i stick to 2 amps keep them both and have the 1800w for my rockford fosgates and the 1000w for my pioneers and wat ya mean by too small a load (told i know nothing) |
Bronze Member Username: Weezer4rock
Post Number: 11 Registered: Dec-07
| Posted on Wednesday, May 14, 2008 - 03:51 pm: |
Perhaps you've heard of ohms before? It's a reference to the resistance "load" of a speaker. Most are 4, 2 or 8 ohms. Most amps can't handle less than a 2 ohm load. Aside from that, having two different brand of subs probably won't mix very well, because each sub design has a different musical timbre. I'd try them both out and pick the one that sounds best. |
DUB-C,
TX
Post Number: 927 Registered: Aug-07
| Posted on Wednesday, May 14, 2008 - 04:27 pm: |
"I'd try them both out and pick the one that sounds best." exactly what i was thinking. |
Bronze Member Username: Chaosofthemasses
Edwardsburg,
Michigan
Usa
Post Number: 11 Registered: May-08
| Posted on Thursday, May 15, 2008 - 12:46 am: |
realisticly you can hook both amps up but will need a capacitor or your alternator will have a heart attack as your battery! and RMS is usually half(not always) the total wattage and this is what you wanna go by not TOTAL WATTS, total watts figures are based from a controlled lab experiment and the consumer cant acheive this level! so ALWAYS look for RMS on any car audio speaker or amp dont be fooled by people saying YEAH IT HITS HARD ITS 1600 watts But 80wx2 RMS. which brings me too my next point DONT BUY CUSPID products they flat out SUCK there wattage is high but RMS is Pathetic! |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1534 Registered: May-07
| Posted on Thursday, May 15, 2008 - 01:00 am: |
FYI- The kenwood amp does 900w @ 2 ohms. Read this....http://www.bcae1.com/ohm.htm Check out some other things on the site too, it will explain most of your questions for anything. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7456 Registered: Jul-06
| Posted on Thursday, May 15, 2008 - 03:16 am: |
" will need a capacitor or your alternator will have a heart attack as your battery! " LMAO. Do not listen to this guy. please. |
Edwardsburg,
Michigan
Usa
Post Number: 17 Registered: May-08
| Posted on Friday, May 16, 2008 - 01:32 am: |
MS is obvious;y rich with deep pockets to constantly offer his opinion for pricey products like a ho alt compared to a cheaper more affordable capacitor! and yes i have had too much power drawing from my amp that has caused my car battery to die! since the capacitor i havent had the problem!Hmm maybe im on to something?!?! I wonder? |
Silver Member Username: Hittin1
LakeCharles LA.,
La
Post Number: 304 Registered: May-07
| Posted on Friday, May 16, 2008 - 03:16 am: |
If you only use 1 sub amp for your best sounding pair of subs.... You should be alright on stock charging... would recommend a good battery. dont mix and match subs... Sounds like chit... capacitors... |
Illinois
United States
Post Number: 1541 Registered: May-07
| Posted on Friday, May 16, 2008 - 06:27 pm: |
"i have had too much power drawing from my amp that has caused my car battery to die! since the capacitor i havent had the problem!" Maybe you forgot to hook the amp back up? Just a thought.... |
