Thread: Power source for deck |
Silver Member Username: Theivan
Dawson Creek,
British Colu...
Post Number: 115 Registered: Mar-07
| Posted on Tuesday, May 13, 2008 - 11:02 pm: |
the wiring harnesss on my 81 pontiac station wagon (GRAD VEHICLE) was cut and i want to put in my jvc deck. is there something i can just take power off of and ground the deck myself? please help i havnt herd my pheonix golds pound in so long!!! |
Relevant Product Info
Dawson Creek,
British Colu...
Post Number: 116 Registered: Mar-07
| Posted on Tuesday, May 13, 2008 - 11:03 pm: |
allready looked for the cig lighter wire its gone too.... |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1214 Registered: May-07
| Posted on Wednesday, May 14, 2008 - 02:50 pm: |
just run a wire to the battery or a power feed to the ac then sand the body somewhere and connect a wire to a bolt or screw drilled into where you sanded and you should be fine. as long as you run a positive to the battery, then make your accesory wire tie into something that gets power when the keys on you should be back to bumpin. |
Dawson Creek,
British Colu...
Post Number: 117 Registered: Mar-07
| Posted on Thursday, May 15, 2008 - 01:48 am: |
ok stuff that turns on with the key, cant think of anything that does in my car haha :P it works without acccesory tho right? |
Old Bridge,
NJ
USA !
Post Number: 1220 Registered: May-07
| Posted on Thursday, May 15, 2008 - 05:10 pm: |
no, acc is basiclly a switch if u hard wire the radio to 12 volts it will always be on and drain the battery. i had a 1986 suburban and i just wired into a power feed for the ac, the other way outwould be run a switch to the accesory and wire the accesory to 12 volts. the only problem is if you ever forget to flip the switch your battery might go dead when the car was parked. |
Dawson Creek,
British Colu...
Post Number: 118 Registered: Mar-07
| Posted on Friday, May 16, 2008 - 01:14 am: |
yeah i got it working it needs this one cord to turn on (not the ground or power) its to the red (accesory cord?) but i still need to turn the deck on and off myself :S but at least it works for now  |
Old Bridge,
NJ
USA !
Post Number: 1235 Registered: May-07
| Posted on Friday, May 16, 2008 - 02:25 am: |
yep that be the acc u can wire that to a switch if you want to. |
Dawson Creek,
British Colu...
Post Number: 119 Registered: Mar-07
| Posted on Sunday, May 18, 2008 - 03:56 am: |
if i do will my deck still remember the time and my preset eq's... u know whats funny is i had two 10s and one of them is blown so i unhooked it and my one sub pounds as hard as both of them did together...makes me wonder why i bought two of them i guess s/q? |
Old Bridge,
NJ
USA !
Post Number: 1241 Registered: May-07
| Posted on Sunday, May 18, 2008 - 03:59 am: |
no ur one was prob blown along time ago and the air preassure in the box made the other move. and as long as you clock wire clk usually yellow is wired to power yes it will remember everything. |
