Thread: Cutting Out |
Bronze Member Username: Deanerjr
Post Number: 56 Registered: Feb-08
| Posted on Tuesday, May 13, 2008 - 09:35 pm: |
Hey, just got my MTX amp installed, along with two 10" Q Power subs. and ive got the in dash etc in already. thing is it bumps great, but it cuts out on certain songs at a certain volume. Wondering is there something i can do? O yea, glad to be back, been dealin with so much sh*t i left for a bit =[[. I be back now lol. :D |
Relevant Product Info
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1211 Registered: May-07
| Posted on Tuesday, May 13, 2008 - 09:47 pm: |
turn your gain down and check the subs wiring as in ohm load. |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16597 Registered: Jun-06
| Posted on Tuesday, May 13, 2008 - 09:49 pm: |
"Cuts out". Does the amp go into protect? |
Post Number: 57 Registered: Feb-08
| Posted on Tuesday, May 13, 2008 - 09:51 pm: |
paul, im thinking the amp goes into protect mode. cause it only happens when a note gets way to low/loud. because some of the time like just a minute ago. it will "Cut out" and the subs wont hit for a few seconds. then once ive turned it back down and waited a second, they will start hittin again. |
Post Number: 58 Registered: Feb-08
| Posted on Tuesday, May 13, 2008 - 10:28 pm: |
also. idk if the ppl who installed it tuned it and fixed the gain right. bout to check my pioneers voltage etc. |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 913 Registered: Jul-07
| Posted on Tuesday, May 13, 2008 - 10:42 pm: |
i think there wired wrong i have done that a couple of times |
Post Number: 59 Registered: Feb-08
| Posted on Tuesday, May 13, 2008 - 11:17 pm: |
it was professionally done. but sh*t, everyone makes mistakes. callin the place up during my 5th period class tomorrow lol. gonna describe whats goin on and see what they got to say. Im out for tonight. hope i got more feedback when im back. Peace. |
Silver Member Username: Surferdude9371
Im BTL Bumpin
Post Number: 909 Registered: Mar-07
| Posted on Wednesday, May 14, 2008 - 10:27 am: |
are you using cds when this happens? the hu may be shaking and skipping that happened to me before |
Post Number: 60 Registered: Feb-08
| Posted on Wednesday, May 14, 2008 - 04:47 pm: |
yes. and no its not. the music continues, BUT the bass will stop hitting. and the f*cktard who helped install it i talked to was like "you could just not turn it up that high, or check the gain.." lol |
