Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Kicker zx750.1 shuts off
Author Thread: Kicker zx750.1 shuts off
Username: Centurybangin
Alright I just bought a zx750.1 amp to power my two type R's, it has been working fine so far but it has shut off a couple times when the music is really loud for like 5 seconds and then it comes back on. In the book it says it is probably not getting enough electricity.
The only reason why I can think of for it not getting enough power is because I have 10 gauge power wires hooked up and the book suggests 4 gauge, would that be why?
Relevant Product Info
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 520
um yes.
switch that out asap. 4 ga is ideal, might just want to run 1/0 gauge if you plan on upgrading later.
i cant believe you got any juice with 10 ga...when u switch it out those Type Rs will come alive!
Username: Drant19
DUB-C, TX
Post Number: 917
get 4ga or smaller on that amp ASAP
Alright thanks a lot guys. Ya I just switched from an alpine mrd-m500 amp and the difference is amazing already I need to go get that 4 gauge wire.
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1212
ether amp kicks azz but damn man you will be lucky u didn't hurt that kicker with that low of wire. heres a rule of thumb. 500 - 1000 rms, 4 guage or higher in wire. but remember the lower the number the thicker the wire is. also 400 or less rms 6 guage and thicker. your best bet is go 4 guage or higher. DO NOT run your system anymore with that tiny of wire or you WILL do damage.
Username: 420alldaylong
Post Number: 3586
Get a Kicker CK4 ampkit complete with RCA's.
Kicker ampkits are good stuff.
Username: Somedonniedude
Illinois
United States
Post Number: 1533
It would be louder with he zx750.1 and proper wiring. Unless it's the old R's, i would switch back to the kicker amp.
Your subs are Dual 2 ohm correct?
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Kicker zx750.1 shuts off [ « Previous ] [ Next » ]
