Thread: $450 need the best amp i can get @1ohm stable |
Bronze Member Username: Trevor_r
Bastrop,
L.A
Us
Post Number: 79 Registered: Jul-07
| Posted on Tuesday, May 13, 2008 - 07:58 pm: |
i have a 9515d i got 450 bucks need as much power as i can get for my buck and as yall know dd9515d wires down 1.4 or .35 can any1 help?????? thanx |
Relevant Product Info
Silver Member Username: Imalik
15 SI Mag9.1=Boom,
New Jersey
Jerzee Playa
Post Number: 589 Registered: May-06
| Posted on Tuesday, May 13, 2008 - 08:48 pm: |
Here you go http://www.audioque.com/aq/AQamps2200D.htm |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 521 Registered: Sep-07
| Posted on Tuesday, May 13, 2008 - 08:51 pm: |
^agreed unless you would consider used... |
Bastrop,
L.A
Us
Post Number: 80 Registered: Jul-07
| Posted on Tuesday, May 13, 2008 - 08:53 pm: |
yeah i can use used lol no problem! |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 4506 Registered: Jan-06
| Posted on Tuesday, May 13, 2008 - 09:12 pm: |
What about that new MTX amp? It is made in Korea like all the new good amps and does more than rated, heard it is in your range...Polo. |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1902 Registered: Mar-06
| Posted on Tuesday, May 13, 2008 - 09:39 pm: |
I can possibly work with you on a RD 1750.1 in that price range. New with warranty. Kevin lowhz01@yahoo.com |
Silver Member Username: Goodie_goop
Mid town,
Texas
U.S.
Post Number: 911 Registered: Oct-06
| Posted on Tuesday, May 13, 2008 - 09:46 pm: |
maybe an orion 2500d if you find one on ca.com or somethin...i think they will do .35 with proper electrical....? |
Gold Member Username: Tejcurrent
Post Number: 1353 Registered: Apr-07
| Posted on Wednesday, May 14, 2008 - 06:44 am: |
Look for a used kicker 2500, memphis 2500, hell even a hifonics 2600 would fit in your budget. Just search the classifieds. |
Gold Member Username: Insearchofbass
Post Number: 9200 Registered: Jun-04
| Posted on Wednesday, May 14, 2008 - 08:58 am: |
my brothered owned a mtx TA92001 and that amp had a birth sheet of 3829 at 1 ohm so id say if you can get that amp youll be producing about 3000 watts rms at 1.4 ohms |
Gold Member Username: 420alldaylong
Post Number: 3587 Registered: Sep-06
| Posted on Wednesday, May 14, 2008 - 04:22 pm: |
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18538 http://audioforum.termpro.com/topic/20/13407.html |
Gold Member Username: Extrmndor3
Http://illuzonemu.serv...,
^^^Sick Game
Post Number: 7923 Registered: Feb-06
| Posted on Wednesday, May 14, 2008 - 06:37 pm: |
kicker kx2500.1 on ebay even the refurbished one |
