Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > Need box design
Author Thread: Need box design
Username: B3n07
Louisville, Ky
Post Number: 908
i need it for 2 audioque hdc315 heres y measuerments and i can go even bigger 33" lenght 38" width 12 1/2" tall. i can go even longer if need
Username: Insearchofbass
Post Number: 9191
go with 2.50 cubic feet net per sub without the port and go with 60 square inches of port
Username: B3n07
Louisville, Ky
Post Number: 909
2.5 for HDC i thought they need atleast 4.5 cuft each
Post Number: 9192
thats what jack's two hdc 15's were in (9 cf gross) 3.20 aprox. cubic feet net after subs and port that I designed but that was under the impression that it would fit in his trunk...but 2.50 should still work well after subs and port because the 83 scriocco we did with two hdc 12's was in 3.35 total cubes net aprox for both 12's after the port and subs and still hits the lows pretty good...what amp and power are you using
Username: B3n07
Louisville, Ky
Post Number: 911
probably going to be using the AQ 2200hd
Username: B3n07
Louisville, Ky
Post Number: 920
can some one design me one with a cut sheet
Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > Need box design [ « Previous ] [ Next » ]
