Home > Message Board > Car Audio > Amplifiers > Want to know more about class D amps..
Author Thread: Want to know more about class D amps..
Username: Rousseau
hi guys..need help to know more about these amps.im new to this car entertainment.so far i just know i need class D amps for the new coming SI Mag.
i really dont know the requirement for my car and these sub.i want to play SQ.
Relevant Product Info
Username: 420alldaylong
Post Number: 3577
This will help you alot.
http://www.bcae1.com/
New SI Mag 12"
1 cubic foot sealed box
Recommended power range: 500-1000 watts RMS
What vehicle do you have?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5340
Great subwoofer.
Username: Rousseau
actually i use malaysia local car..i think the bonnet is can fit 2 cubic feet box.
Username: Nd4spd18
Northwest PA
Post Number: 7461
Read:
http://www.bcae1.com/ampclass.htm
Cliffs notes:
Class D amplifiers are much more efficient than standard class AB amplifiers, but they can only be used to drive subwoofers, because the transistors switch at frequencies that would audible and cause interference on full range speakers.
Username: Rousseau
Post Number: 8
ok..i will check it later.thank guys..
Username: Rousseau
Post Number: 9
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > Want to know more about class D amps.. [ « Previous ] [ Next » ]
