Thread: DEH-P80MP (or similar) owners |
Gold Member Username: Livin_loud
COD4 Addict ...
Level 2 pre...
Post Number: 2449 Registered: Jan-06
| Posted on Tuesday, May 13, 2008 - 12:49 am: |
i just attempted to wire this unit in my buddys truck and it will not power on. i noticed the harness doesn't have a blue REM wire... don't know if it should or not. and what is with the 60w option? also, what is with the ACC and Battery (red and yellow) wires with the fuses and boxes? |
Relevant Product Info
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 907 Registered: Jul-07
| Posted on Tuesday, May 13, 2008 - 11:28 am: |
try hooking it up to the power antenna |
Gold Member Username: Stateprop486
PA
Post Number: 1502 Registered: Jan-08
| Posted on Tuesday, May 13, 2008 - 11:45 am: |
does it have the blue/white wire cuz thats what your need to hook up your amp remote wire too. "what is with the ACC and Battery (red and yellow) wires with the fuses and boxes?" ^did you hook them up? if not there is your problem right there....the fuses are for incase you hook it up wrong and it blows out the fuse b4 it damages your HU. |
COD4 Addict ...
Level 2 pre...
Post Number: 2450 Registered: Jan-06
| Posted on Tuesday, May 13, 2008 - 01:36 pm: |
he doesn't have an amp yet, so no need for the blue/white. the harness for the HU doesn't have a solid blue wire though, so i don't know how it turns on and off... i connected every wire, except the orange/white because his truck doesn't have one. it's a 99 dakota sport btw. i'm confused as to what powers this thing, the red "acc" or the yellow "battery". like i said i had both hooked up... also noticed he has a rather larger red wire connected to a green wire coming from inside the dash. it was screwed onto the back of his old HU. pretty sure it was ground... when i touched it to the back of the new Pio it sparked |
Louisville,
Ky
Post Number: 912 Registered: Jul-07
| Posted on Tuesday, May 13, 2008 - 01:59 pm: |
you always have to have the rem hooked no matter what thats what turns the radio on |
COD4 Addict ...
Level 2 pre...
Post Number: 2451 Registered: Jan-06
| Posted on Tuesday, May 13, 2008 - 06:01 pm: |
i know that Ben. lol. i'm saying the HU harness doesnt have one, nor did his old jvc.. im dumbfounded as to how it powered on before |
Louisville,
Ky
Post Number: 916 Registered: Jul-07
| Posted on Tuesday, May 13, 2008 - 10:54 pm: |
dose it have a power antenna hook up there |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6387 Registered: Mar-04
| Posted on Tuesday, May 13, 2008 - 11:18 pm: |
quote:also noticed he has a rather larger red wire connected to a green wire coming from inside the dash. it was screwed onto the back of his old HU. pretty sure it was ground... when i touched it to the back of the new Pio it sparked
If it sparked when it touched the back of the HU, then 1 of 3 things is going on. 1- That wire was not a ground, but rather a + 2- You have the HU wired incorrectly. (ground to +, + to ground) 3- The HU is fried internally. Did you use a wire harness to connect to the stock harness or cut into the stock harness? Most of Pioneer's higher end radios have inline fuses (the 6000 and up series). Blue/white wire is remote...if that HU doesn't have one, you are missing a pin from the HU's harness. |
Silver Member Username: Explictx
Glen Burnie,
Maryland
Post Number: 590 Registered: Mar-07
| Posted on Wednesday, May 14, 2008 - 09:10 am: |
Try taking the ignition wire from the radio and touching it with the 12v wire. see if it comes on. |
COD4 Addict ...
Level 2 pre...
Post Number: 2453 Registered: Jan-06
| Posted on Friday, May 16, 2008 - 02:10 pm: |
turned out to be the "radio" fuse in his truck  |
