Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > Port Question?
Author Thread: Port Question?
Username: Dynamik
Post Number: 60
Does the width of the opening of the port matter when it comes to tuning? I mean is it better to have a longer/narrower port or a wider/shorter port...or does it matter?
Relevant Product Info
A pic is worth
1000 posts!!
Post Number: 16583
It matters. Too narrow a port will cause "port noise".
Username: Dynamik
Post Number: 61
Well, I was thinking about 2.5" opening for my port, tuned to 29 Hz and 3 ft^3... I wonder if that .5 ft^3 would matter since my Sub is a 15" Mag, and they suggest 3.5 ft^3??? Any suggestions?
A pic is worth
1000 posts!!
Post Number: 16587
Add a little poly to compensate for lack of volume.
Username: Somedonniedude
Illinois
United States
Post Number: 1527
Do you have the room to go bigger? If you are limited on space, try some aero ports.
Username: Dynamik
Post Number: 62
Yea, I have the space to go bigger if necessary...
Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > Port Question? [ « Previous ] [ Next » ]
