Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > AQ SD.2 15s in a 04 IMPALA help
Author Thread: AQ SD.2 15s in a 04 IMPALA help
Username: Killerzracing71
Post Number: 2173
Trying to set a system up for my boy
like it says 04 imp
37 WIDE
18" HIGH
40 DEEP
Since subwoofertools is sorta gone i cant make up a box for him
i belive thats way more then 9 cubes but how much port should i run
Username: 420alldaylong
Post Number: 3575
Email AudioQue and tell them what you are working with and DJ will hook you up.
sales@audioque.com
A friend of mind has 2 AQ SD2.5 15's on a Crossfire VR1000D(around 1400RMS@1ohm) and it beats hard and sounds good. But not sure on the cf. or Hz but the box is big as hell.
What kind of power are you going to be using? I would recommend at least 1000RMS to 1800RMS.
Username: Insearchofbass
Post Number: 9181
do 2.5 cubes net tuned to 35 hz each 15 but you could go as small as 2.0 cubes net per 15
Post Number: 2174
word yeah if he does go with this setup he will run a AQ 1200D so hell be set
Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > AQ SD.2 15s in a 04 IMPALA help [ « Previous ] [ Next » ]
