Thread: 2 12" alpine type s |
Silver Member Username: Dirtrider125
Post Number: 121 Registered: Apr-07
| Posted on Saturday, May 10, 2008 - 08:12 pm: |
im probly gonna buy 2 of them and get rid of 1 12" type r. how will they sound compared to that and will they be better sealed or ported? |
Gold Member Username: Joebruce
TC Sounds/DLS
Post Number: 2086 Registered: May-04
| Posted on Saturday, May 10, 2008 - 08:58 pm: |
I dont like the Type-S. I would just keep the Type-R and maybe get another one. Why do you want to switch from type-R to Type-S? Thats going down a step. What kind of enclosure do you have the type r in now? What amp do you have on the Type-R? |
Post Number: 123 Registered: Apr-07
| Posted on Saturday, May 10, 2008 - 09:23 pm: |
why dont you like the type s i want to switch because i want 2 12s and the amp i have is a kx450.2 and the type r i have is dual 4 ohm and can only be wired at 2 ohms so i cant bridge it and its only gettin like 300 rms i have it in a sealed box im sure 2 type s will be louder. |
Post Number: 124 Registered: Apr-07
| Posted on Saturday, May 10, 2008 - 09:24 pm: |
2 type s ported wit a kx450.2 i dont need a competition system i just want somethin that sounds pretty good and gets pretty loud |
Post Number: 125 Registered: Apr-07
| Posted on Saturday, May 10, 2008 - 09:27 pm: |
i would just get another type r but then id have to get a different amp and i dont feel like doin all that |
TC Sounds/DLS
Post Number: 2088 Registered: May-04
| Posted on Saturday, May 10, 2008 - 09:43 pm: |
Well I would still just keep the 1 Type-R. If its in a sealed enclosure try it in a ported one,it will sound alot better. I dont like the type-S because they sound terrible,IMO, and just feel cheap. Also you are underpowering the Type-R. Try giving it around 800wrms and it will sound great. If I were you,instead of buying 2 new subs id sell that amp and get one that will do like 700-800wrms. |
Silver Member Username: Spankinurwoofers
GR,
MI
US
Post Number: 385 Registered: Nov-07
| Posted on Saturday, May 10, 2008 - 10:57 pm: |
you can get audiobahn A8000T's(or the A8002T, for different wiring) pretty cheap on ebay, they do a little under 800 wrms i believe...I had 4 at one point  |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1511 Registered: May-07
| Posted on Sunday, May 11, 2008 - 12:14 am: |
I had a 12" alpine type-s. I would save my money for something better IMO, or go with new (bigger) amp for your type-R. |
Post Number: 131 Registered: Apr-07
| Posted on Sunday, May 11, 2008 - 12:19 am: |
y what kind of box was it in and what amp? u think 1 type r with 800 rms will be louder than 2 type s ported |
Illinois
United States
Post Number: 1513 Registered: May-07
| Posted on Sunday, May 11, 2008 - 12:30 am: |
I had mine sealed in a 1.25cf (before sub disp). Ran around 350w to it off a rockford P6002. Never heard a Type-R, but have heard alot of nice things about them. |
Gold Member Username: Crayola0
Portage,
Wisconsin
Post Number: 2393 Registered: Jun-06
| Posted on Sunday, May 11, 2008 - 10:55 pm: |
ya it could depends on the enclosure. there are some videos on the web of 1 15 in a ported enclosure hittin 140+ |
