Thread: Class D amps for soundstage? |
Bronze Member Username: Peakohm
Post Number: 92 Registered: Apr-08
| Posted on Saturday, May 10, 2008 - 03:10 pm: |
Okay, now I can't honestly say I've ever heard a class D used for front/rear component speakers. Some say that compared to an AB amp it is bad, then I've heard others that say there is no difference. I was looking at getting this eclipse amp, but I'm more looking for SQ if there is going to that much of a difference... http://www.eclipse-web.com/amp/xa4200.html anyone have any experience/opinions? |
Diamond Member Username: Bestmankind
Post Number: 20792 Registered: Oct-05
| Posted on Saturday, May 10, 2008 - 03:22 pm: |
you want to use that for your front or rear comp speakers? if so you can't. it only goes up to 500hz. that is the case with all the class d amps. the frequency range is limited so you can't use it for comps. |
Post Number: 94 Registered: Apr-08
| Posted on Saturday, May 10, 2008 - 03:27 pm: |
yeah, front and rear speakers. maybe I missed where it only went to 500hz I looked it over a few times and it looks like it will drive full range speakers to me  |
Post Number: 20793 Registered: Oct-05
| Posted on Saturday, May 10, 2008 - 03:30 pm: |
oh my bad. i read the frequency response and it says it goes up to 500hz. but then i saw it again and that was the xover range. yeah you can use that. lol. sorry dude. |
Post Number: 95 Registered: Apr-08
| Posted on Saturday, May 10, 2008 - 03:32 pm: |
lol it's all good man. i was like damn maybe i missed it somewhere! i've heard it sounds good but i was just curious about class D vs AB. i guess we shall see if i get it... |
