Thread: Kenwood KDC-V6017 NO SOUND |
New member Username: Jer0jon
Post Number: 1 Registered: May-08
| Posted on Saturday, May 10, 2008 - 12:57 pm: |
I bought a Kenwood KDC-V6017 Deck it powers up and all the functions work but I have no sound does anyone know what could be wrong |
Relevant Product Info
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1203 Registered: May-07
| Posted on Sunday, May 11, 2008 - 12:16 am: |
check connections to your speakers and fader settings otherwise internal amp could be blown , did you buy new? |
Post Number: 2 Registered: May-08
| Posted on Sunday, May 11, 2008 - 11:39 am: |
I bought it used, I double and triple checked conections, so it must be the amp, is the stereo worth fixing or do you think it is junk? |
Old Bridge,
NJ
USA !
Post Number: 1206 Registered: May-07
| Posted on Sunday, May 11, 2008 - 02:32 pm: |
only way you can prob fix it would be sending it back to kenwood. unless u paid a hefty price, it's probably far from worth it. if u decide to junk it do 2 things before you do. 1 check the back of the unit for fueses see if any are blown, 2 opwn the housing of th unit and take a look inside see if you find any internal fuses and replace them to. one last thing i can thing of, if theres a harness, check the pins in the harness and see if they are intact and not pulled out. oh and have u everchecked to make sure a speaker wasn't groundng out on the body of the car? |
Post Number: 3 Registered: May-08
| Posted on Sunday, May 11, 2008 - 10:50 pm: |
thanks for all the info I will give it a try |
