Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Kicker Amp Advice
Author Thread: Kicker Amp Advice
Username: Blublud
Hello all. I recently purchased a Dodge Dakota regular cab and have two Kicker CVT-10 subs, each in it's own box behind the seats. Anyone have an amp idea? I'd like to stay with Kicker, as I can get it resonably quickly and inexpensive through a dealer and I'd also like to only have one amp running the two speakers.
Username: 04redmach1
Lagrange, GA
Post Number: 1871
Are your subs dual 2 or 4 ohm?
Kevin
Username: Blublud
They are dual 4 ohm.
Username: 420alldaylong
Post Number: 3560
Kicker SX600.2
Kicker ZX850.2
4ohm bridged^^^^^
Or you could go with a Rockford T3002 and run it at 1ohm stereo.
T3002 $179 at OnlineCarStereo.com and it will bang those 2 10's you got.
Username: Somedonniedude
Illinois
United States
Post Number: 1523
Joey what do you mean by running the rockford @ 1 ohm stero? Wouldn't he be able to only run them @ 2 ohm stereo?
Username: Safe_cracker
Chicago, IL
US
Post Number: 4495
Kicker KX or SX 1200.1, both can be ran 1ohm mono. Polo..
Columbus, GA
Post Number: 1892
We have the RD 850.1's and 1000.1's on sale right now. They will get you some good power at 1 ohm.
Kevin
lowhz01@yahoo.com
Post Number: 3563
SomeDonnieDude
All of the Rockford Power Series(2 channel amps)that look like the one's in the link below can be run at.
4ohm Stereo
2ohm Stereo
1ohm Stereo
4ohm Bridged Mono
2ohm Bridged Mono
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=7 &family_id=23&item_id=100031&locale=en_US
http://www.rockfordfosgate.com/products/amp_power_output.asp
Kickazz underated amps.^^^^^
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5329
i'm with kevin... Great quality amps
Illinois
United States
Post Number: 1529
Joey, He has Dual 4 ohm subs tho.
Post Number: 3578
And?
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 516
price range? up to $200ish?
Illinois
United States
Post Number: 1532
Oh you were meaning running the amp mono...you put stereo. I thought you were talking about running the amp on 1 channel or something weird lol.
Username: Blublud
Thanks for the strong response. I think I'm going to go with the ZX850.2 and run at 4ohm. The truck box that I've purchased to put them in suggests that that wiring would be best for my purposes. Thanks everyone who responded.
Post Number: 3585
Kicker amps are kickazz but that Rockford T3002 I mentioned above will do the job for less money.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5334
i'd run class D amp instead of 2 channel... more efficient
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Kicker Amp Advice [ « Previous ] [ Next » ]
