Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > Putting the new system together..
Author Thread: Putting the new system together..
Username: Palanza
Post Number: 194
Just picked up a new (used) car today. 2000 Pontiac Grand am SE 3.4L v6 40,000 miles 4,600$
Time for the install. Gosh its annoying how quickly the little things can add up in price
Pontiac Kit 1995-up, S/E
GM Wire Harness receiver, 1985-up
GM Antenna Adapter "New" OEM radio M to Motorola ant F
StreetWires FB0 1/0-ga. Firewall Bushing
Kolossus Fleks Kable 1/0 Black Power/Ground Wire
Kolossus Fleks Kable 1/0 Red Power/Ground Wire
KonFUSED 2 Way Distribution System (150A,150A)
Karma SS 12 Gauge Speaker Wire - 100 Feet
Gold Plated 1/0 Ring Terminal - Black
Gold Plated 1/0 Ring Terminal -Red
Karma SS 2 Channel 6 Meter RCA Cable
General Motors Side Post Battery Terminal
Kolossus Fleks Kable 4 Gauge Black Power/Ground Wire
Kolossus Fleks Kable 4 Gauge Red Power/Ground Wire
Negative Battery Terminal
Positive Battery Terminal
KENWOOD KDC-X991 Headunit
Previously purchased parts:
(2) 13.5 W6v2's
1000/1v2
300/2
CDT 6.5 M6 Comps with silk DRT-25 tweets in a braxial setup.
Sooooo now that all is left is to pick up some outrageous amount of sound deadener. I'm thinking second skin damplifier will do the trick. Ultimately I plan to pop in a yellow top in the trunk and add a H/O alt, but my budget is pretty much blown as it is, so thats going to have to wait a bit.
Any suggestions? I think it'll sound pretty good once I get it all together.
Username: Joebruce
TC Sounds/DLS
Post Number: 2081
Sounds like a nice setup man. You'll be more than happy once its installed.
Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > Putting the new system together.. [ « Previous ] [ Next » ]
