Thread: Someone help me with this chevy |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 887 Registered: Jul-07
| Posted on Friday, May 09, 2008 - 01:49 pm: |
my buddy has a 2004 chevy colarado he wants to put and aftermarket radio in well he went to the shop to buy the radio and they tod him he needs a 175 dollar adapter to keep the door chime ad airbags. dose he need it and can he get arround buying it. |
Silver Member Username: Mmaudioconcepts
Post Number: 486 Registered: Jan-07
| Posted on Friday, May 09, 2008 - 02:14 pm: |
but it at walmart around ($50). i had the same issue with a 2006 impala |
Gold Member Username: Jtown
Team RD,
Texas
Post Number: 2863 Registered: Mar-07
| Posted on Friday, May 09, 2008 - 03:02 pm: |
I wouldn't doubt it, chevys are a b1tch to install stuff in. I'm working on running wiring and new comps right now. |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6372 Registered: Mar-04
| Posted on Friday, May 09, 2008 - 03:47 pm: |
$175... Is that w/ install? We sell the Metra GMRC-01 harnesses for $89.95 here at the shop. Kit, harness, antenna, and install (w/ warrantied labor) here would be ~$165-175 |
Silver Member Username: Turnmat
Racine,
Wi
Post Number: 704 Registered: Feb-07
| Posted on Friday, May 09, 2008 - 05:45 pm: |
I needed it for my 06 Chevy impala too. If you want the door chimes and all the extras like on-star and such to work you need the kit. I would look at different shops or go buy the kit somewhere else |
Gold Member Username: Insearchofbass
Post Number: 9165 Registered: Jun-04
This looks like it might be what your looking for 68.22 Note: Will not work with OnStar equipped vehicles http://www.audiooutfitter.com/gmrc-01/metra/p73875.html
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1199 Registered: May-07
| Posted on Friday, May 09, 2008 - 10:57 pm: |
as was mentioned, yes u need the adapter if u don't get it it can screw up the cars ecu, from what i seen the voltage is touchy and all the main computers power is tied into the radio, without the adapter you screw up the voltage i herd and screw up ur cars vitals. |
