Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > What was that 24?
Author Thread: What was that 24?
Username: Deadrabit
Post Number: 374
what is this? link to buying them? specs?
http://www.putfile.com/pic/7848452
Username: Stateprop486
PA
Post Number: 1498
thats chad lee holdin it.
Username: Deadrabit
Post Number: 375
chad lee! i want to know some stuff on this thing!
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 2066
Tell us about it Chad????
That's not Chad...
A pic is worth
1000 posts!!
Post Number: 16513
That was Chad holding an Atomic ELE 24 sub.
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1196
maybe george decay instead?
Username: Deadrabit
Post Number: 376
who cares who it is! what is it!
Username: Crayola0
Portage, Wisconsin
Post Number: 2385
www.atomicspeakers.com its the E.L.E 24 i beleive
Username: Turnmat
Racine, Wi
Post Number: 694
It has the cone area of three 15" sub's. I would take the three 15's over just that one sub. JMO
Username: Turnmat
Racine, Wi
Post Number: 696
Here is some info on them thanks to their site
* Rigid Die cast aluminum basket
* Organic long fiber cone body for accurate tight bass
* Highly damped fiberglass reinforced cone body
* Extended neck joints on cone, coil and spider strengthen the integrity of moving structure for high power capacity
* resin impregnated cloth surround ensure lasting performance
* vented coil for extra heat dissipation
* 4 inch high temp aluminum voice coil
* Powerful double stacked high energy magnet
* high energy motor structure
* reinforced resin impregnated polycotton spider extend the life span of the speaker from material fatigue and collapse.
* integrated heavy duty lead wire on spider prevent short circuit and melt down
* dome shape dust cap design
* low carbon front and back plate
* Vented magnetic Blast technology
* Laser etched, machined and chromed back plate
* 2000Watts
Username: Deadrabit
Post Number: 377
E.L.E. (Extinction Level Event )
UNITS ELE24D4
Revc (ohms ) 2.00
Fo (Hz) 19.60
Sd (sqM) 0.267
Bl ™ 28.24
SPLo (dB) 95.30
Xmax (mm) 15
Dvc (mm) 100
Qms (m.q.) 5.20
Qes (e.q.) 0.266
Qts (totQ) 0.253
Vas (liter) 774
Cms (uM-N) 76.5
Mms (gram) 341
what do u think? is it worth it?
Username: Snowball123
West Allis, WI
United States
Post Number: 641
looks g*y to me.
Username: Safe_cracker
Chicago, IL
US
Post Number: 4484
Actually that is a phillipino and he is holding a 12" lOl. If it was Chad he would at least make it look like a 15... Polo. :-O
Home > Message Board > Car Audio > Subwoofers > Archive through May 15, 2008 > What was that 24? [ « Previous ] [ Next » ]
