Thread: OT- In need of a GOOD 2/4 channel amp any ideas? |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 4475 Registered: Jan-06
| Posted on Thursday, May 08, 2008 - 11:10 am: |
I need 200rms per channel into four channels at 4ohms or 400rms into two channels at 2ohm. I was looking at a Soundstream Van Gogh 800.2 any other ideas would be greatly appreciated... Polo.. |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5768 Registered: Feb-06
| Posted on Thursday, May 08, 2008 - 11:25 am: |
SX fried? |
Gold Member Username: Loc_out
Santa Ana,
Ca
Resonant Eng...
Post Number: 2059 Registered: Feb-05
| Posted on Thursday, May 08, 2008 - 11:29 am: |
Polo you should know better. Please post on the right section. j/k -Lowlife |
Gold Member Username: Insearchofbass
Post Number: 9160 Registered: Jun-04
brand new from Sonic Electronix...same power at 1-4 ohms and it has four channels http://cgi.ebay.com/Brand-New-Pheonix-Gold-800-Watt-Multi-Channel-Xenon_W0QQitem Z260237492595QQihZ016QQcategoryZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Brand New Pheonix Gold 800 Watt Multi Channel Xenon * 800 Watt Power Amplifier * High efficiency (greater than 80%) Class D Operation * Xe.load™: optimized for any impedance load * Xe.tune™: 24dB Linkwitz-Riley subsonic and low pass crossovers * Xe.flow™: variable thermal feedback controlled fans * Tried and true triple Darlington output stage * Buffered RCA full range thru output * Remote Monitoring Display (RMD) port * Low Pass Level control ready (LPL-44) * 200W x 4 (4-1 ohm stereo) * 400W x 2 (8-2 ohm bridged) * Built-in Crossovers * Optional Remote Voltage Display * Optional Remote Low-Pass Level Control * Variable input sensitivty * 0 - 18dB Bass Boost at 45Hz * CEA-2006 Compliant * Dimensions: 22" L x 10.6" W x 2.5" H * 1-year Sonic Electronix warranty |
Chicago,
IL
US
Post Number: 4476 Registered: Jan-06
| Posted on Thursday, May 08, 2008 - 11:31 am: |
I think the transformer is gone can't find the short and really don't have the time to fix it, sucks. I changed everything out, scoped out perfect, nice waveform used it in-car for a week and a half. I went to turn it on the other day and it shut off again, funny thing is it never went into protect and it never smoked BUT it did take a whole set of power supply fets with it, again just plain tired ya know? Polo.. |
Chicago,
IL
US
Post Number: 4477 Registered: Jan-06
| Posted on Thursday, May 08, 2008 - 11:37 am: |
Nice Sean it would be Ideal but it is a class D need it in A/B for use with comps needs to be clean. Polo. |
Post Number: 5770 Registered: Feb-06
No I don't know, but I'm sorry that happened to you. It looks like Sean posted a winner, though. |
Diamond Member Username: Bestmankind
Post Number: 20762 Registered: Oct-05
rockford fosgate p850.2 * 2-channel car amplifier * 225 watts RMS x 2 at 4 ohms (425 watts RMS x 2 at 2 ohms) * 850 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode) * variable high- and low-pass filters (40-400 Hz, 12 dB per octave) * wired Punch Bass EQ (0-18 dB at 45 Hz) * Focused Mass Heatsink design * removable connector cover * TO-247 MOSFETs run cooler than standard transistors * CEA-2006 compliant * preamp inputs and outputs * fuse rating: 40A x 3 * 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier * 17-3/4"W x 2-1/8"H x 11"D |
Post Number: 9161 Registered: Jun-04
| Posted on Thursday, May 08, 2008 - 11:42 am: |
wait scratch that its not through Sonic Electronix...he just copied that from them it looks like...but your not interested in it anyway |
Santa Ana,
Ca
Resonant Eng...
Post Number: 2060 Registered: Feb-05
| Posted on Thursday, May 08, 2008 - 11:43 am: |
PG amp is a * High efficiency (greater than 80%) Class D Operation |
Chicago,
IL
US
Post Number: 4479 Registered: Jan-06
| Posted on Thursday, May 08, 2008 - 11:46 am: |
Anyone have any experiences with US amps MD22's? Maybe a pair of them ? Polo. |
Post Number: 20763 Registered: Oct-05
| Posted on Thursday, May 08, 2008 - 11:52 am: |
good amps man. you can't go wrong. why do you need so much power may i ask? |
Silver Member Username: Kickerman
Post Number: 220 Registered: May-06
| Posted on Thursday, May 08, 2008 - 12:38 pm: |
would u sell the sx |
Chicago,
IL
US
Post Number: 4480 Registered: Jan-06
| Posted on Thursday, May 08, 2008 - 02:52 pm: |
The SX needs to be sent in to Kicker for repair. I am good repairing amps but when it is coupled with digital electronics (DSP board) it tends to complicate stuff, not to mention A/B can be a PITA. BTW Chad I just want enough power, the CVL's Sound best on 200rms, they get really loud just the way I like it. It is like me running my IA40 on a 16v system, you really don't need all that power but it is sure nice having it when you are in the mood to bump the punks in front of you! Polo. |
Post Number: 221 Registered: May-06
| Posted on Thursday, May 08, 2008 - 03:58 pm: |
i understand it needs to be repaired i just wanted 2 know if u would sell it as is |
Chicago,
IL
US
Post Number: 4481 Registered: Jan-06
| Posted on Thursday, May 08, 2008 - 05:04 pm: |
Yes. Polo. |
Chicago,
IL
US
Post Number: 4482 Registered: Jan-06
| Posted on Thursday, May 08, 2008 - 06:53 pm: |
Hey how are the little ALPINE MRP-F450 ? Was thinking about a pair of them. Polo.. |
