Thread: OT: 2007 Cobalt LS 4DR |
Silver Member Username: Fac3l3ss
Post Number: 148 Registered: Oct-05
| Posted on Wednesday, May 07, 2008 - 09:18 pm: |
hi everyone..to begin i'll make this short and to the point. i'm looking for a system for my car and would greatly appreciate some help. |
Post Number: 149 Registered: Oct-05
| Posted on Wednesday, May 07, 2008 - 10:24 pm: |
http://www.mobiletoys.com/partners/jvc_fitguide/pages/mobileEntertainment/produc tSelection.aspx that's the link to jvc's mobile audio site..i might like to go with jvc i was actually quite impressed with my last hu and speakers i bought...has anyone heard these speakers..and i was thinking of also getting the kameleon hu...any input appreciated |
Post Number: 150 Registered: Oct-05
| Posted on Wednesday, May 07, 2008 - 10:31 pm: |
i like to very fine tune my music..a 3 band parametric iEQ...better than have a 7 band eq? and how many preouts does kameleon have and volts/channel? i might not make much sense but i'm new to this and want a good sq system |
Gold Member Username: Mgbcs
Lincoln,
Nebraska
Post Number: 2478 Registered: Dec-06
| Posted on Wednesday, May 07, 2008 - 11:45 pm: |
What all are you looking for? Speakers, subs, amps, HU? |
Post Number: 151 Registered: Oct-05
| Posted on Thursday, May 08, 2008 - 09:41 pm: |
a hu, amp, and front 6.5 speakers |
Silver Member Username: Dirtrider125
Post Number: 118 Registered: Apr-07
| Posted on Friday, May 09, 2008 - 12:07 am: |
id get a alpine amp and speakers and if u want a jv hu id get this http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19062 |
Post Number: 152 Registered: Oct-05
| Posted on Friday, May 09, 2008 - 08:41 pm: |
i looked up alpine type s on youtube and they looked decent...alpine good sq? |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 884 Registered: Aug-07
| Posted on Friday, May 09, 2008 - 09:01 pm: |
how much do u want to spend on everything? "i'm new to this and want a good sq system" SQ is not cheap... |
Gold Member Username: Ctmike
Ct.
Post Number: 6084 Registered: Feb-06
| Posted on Friday, May 09, 2008 - 09:04 pm: |
you could buy my 15" atlas for cheap. great sq sub |
Post Number: 153 Registered: Oct-05
| Posted on Friday, May 09, 2008 - 09:08 pm: |
alpine and rf are two brands i can get my hands on around here through local stores..which is better sq? |
Post Number: 154 Registered: Oct-05
| Posted on Friday, May 09, 2008 - 09:11 pm: |
for an amp, hu and two good 6.5 and 6x9 speakers i'd like to stay under $1000 i don't have to have the 6x9's right now though..just 6.5's to replace current ones |
Post Number: 155 Registered: Oct-05
| Posted on Friday, May 09, 2008 - 09:14 pm: |
if i can get away with just an amp and two 6.5's that would be okay as well as long as i'd be able to use the stock hu |
DUB-C,
TX
Post Number: 885 Registered: Aug-07
| Posted on Friday, May 09, 2008 - 09:18 pm: |
i would just leave the stock 6x9s and run them off the headunit. a good sound stage has all the sound coming in front of you. HU-Alpine 9886 ~270 Comps-alpine spxPRO 6.75" ~360 Comp Amp-Alpine F450 200rmsx2 bridged @4ohms OR RF P450.4 Both are ~200 online theres too many options you can get. |
Post Number: 156 Registered: Oct-05
| Posted on Friday, May 09, 2008 - 09:33 pm: |
there is no place unless modified i can fit those tweeters?...i don't want to modify..so unfortunately i have to go without components..unless there is a way you can install those tweeters without cutting away at dashboard |
Post Number: 157 Registered: Oct-05
| Posted on Friday, May 09, 2008 - 09:38 pm: |
keep in mind i don't want to have to modify my power supply at all or very little |
Post Number: 158 Registered: Oct-05
| Posted on Friday, May 09, 2008 - 09:39 pm: |
this setup is not for competition just everyday driving to and from work 45 minute drive each way |
DUB-C,
TX
Post Number: 886 Registered: Aug-07
| Posted on Saturday, May 10, 2008 - 12:06 am: |
if you have stock tweeters, see if you can just switch them out |
Post Number: 160 Registered: Oct-05
| Posted on Saturday, May 10, 2008 - 12:29 pm: |
i don't have stock tweeters on my dashboard |
