Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > Odd problem
Author Thread: Odd problem
Username: Prozack52
Cincinnati, 2-D615D4 Dia...
Post Number: 323
well my voltage of my system continually drops i talked about it before on here so out od curiousty i unhooked the system totally started my truck turned headlights on and AC all the way up voltage dropping in the 12's thats odd so i check my battery tested good checked charging on alt well its charging and checked tightness of my big three sexy anyone one have any ideas what may be going on in my truck
Username: Van_man
Boston South, MA
Post Number: 3917
perhaps the voltage regulater is going. Whats the voltage at the bat when running and when off?
Username: Davidt487
Texas
Post Number: 129
my pickup does something similar unless i turn on the headlights.
i think it is the regulator
Username: Prozack52
Post Number: 324
fair enough but what the chances of the voltage regulator being bad in three diff alt that i have had on this truck in the past year??? i would say slim to none because the voltage regulator is located in the alternator correct
Username: Kingtutus
Lincoln, Nebraska
U.s.a
Post Number: 280
not always
Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > Odd problem [ « Previous ] [ Next » ]
