Thread: Help with amp set up |
New member Username: Spads8
Post Number: 5 Registered: Apr-08
| Posted on Wednesday, May 07, 2008 - 06:08 pm: |
hey i was just wonderin if i would be able to run my TMA T12S4P at 2 ohms from the amp |
Relevant Product Info
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 865 Registered: Aug-07
| Posted on Wednesday, May 07, 2008 - 06:32 pm: |
no, that is a single 4ohm sub. u can only run it at 4ohms unless you have a pair of them. |
Post Number: 6 Registered: Apr-08
| Posted on Thursday, May 08, 2008 - 12:42 pm: |
i do have a pair |
DUB-C,
TX
Post Number: 876 Registered: Aug-07
| Posted on Thursday, May 08, 2008 - 02:04 pm: |
then yes you can run them in 2 ohms. what amp do you have? are you sure that the amp can run in 2 ohms? |
Post Number: 7 Registered: Apr-08
| Posted on Friday, May 09, 2008 - 12:29 am: |
its an mtx tc2002 im pretty sure it can i had it that way with my old mtx sub |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1575 Registered: Mar-04
| Posted on Friday, May 09, 2008 - 01:19 am: |
not bridged at 2 ohms, at least you're not supposed to. Like most 2/4 channel class a/b's it's only supposed to be 4 ohm stable when bridged. |
Post Number: 8 Registered: Apr-08
| Posted on Friday, May 09, 2008 - 05:25 pm: |
it has two 2ohm out puts and can be bridged to 4ohms. should i leave it at 4ohms or put it to 2ohm? |
DUB-C,
TX
Post Number: 880 Registered: Aug-07
| Posted on Friday, May 09, 2008 - 06:14 pm: |
your only option is to have 1 sub per channel that way you can hook them up at 4ohms |
