Thread: Which one would you go with |
Silver Member Username: Prozack52
Cincinnati,
2-D615D4 Dia...
Post Number: 318 Registered: Feb-08
| Posted on Wednesday, May 07, 2008 - 02:13 pm: |
12" JLW7 or 12" Alpine type x |
Silver Member Username: Treez
Its not loud til it he...
Post Number: 358 Registered: Aug-06
| Posted on Wednesday, May 07, 2008 - 02:19 pm: |
I guess you're looking for SQL. But you gotta provide some more info. Are u getting a deal on either sub? W7; SQL Type X; SQ (from what i've heard) |
Cincinnati,
2-D615D4 Dia...
Post Number: 319 Registered: Feb-08
| Posted on Wednesday, May 07, 2008 - 02:28 pm: |
i can get deals on either one just which one is going to sound the cleanest and loudest with a 1000 rms going to it in a s-10 |
Cincinnati,
2-D615D4 Dia...
Post Number: 320 Registered: Feb-08
| Posted on Wednesday, May 07, 2008 - 02:34 pm: |
ok what sub would give the smoothest tightest and most accurate bass |
Gold Member Username: Loc_out
Santa Ana,
Ca
Resonant Eng...
Post Number: 2055 Registered: Feb-05
| Posted on Wednesday, May 07, 2008 - 02:39 pm: |
12w7 imo. What amp you plan on runnign it with. |
Cincinnati,
2-D615D4 Dia...
Post Number: 321 Registered: Feb-08
| Posted on Wednesday, May 07, 2008 - 02:45 pm: |
MRP-M1000 |
Post Number: 359 Registered: Aug-06
| Posted on Wednesday, May 07, 2008 - 02:48 pm: |
Cant assist you on that one as i've never heard the type X, but i've heard that the w7's power handling has increased suggesting increased output. I can be certain about one thing, The w7 will be loud and sound great. But if you're searching for audiophile quality, you can consider the w6v2 among many others.. |
Gold Member Username: Nyyfan13
15 MAG
Post Number: 9543 Registered: Jul-06
| Posted on Wednesday, May 07, 2008 - 02:50 pm: |
The type x is suited for a small sealed box so if space is a concern the thats not a bad route to go |
Gold Member Username: Joebruce
TC Sounds/DLS
Post Number: 2072 Registered: May-04
| Posted on Wednesday, May 07, 2008 - 02:52 pm: |
Out of the 2,W7 ftw! |
Bronze Member Username: Peakohm
Post Number: 85 Registered: Apr-08
never heard the type x but i'd go with JL for sq |
Gold Member Username: Tejcurrent
Post Number: 1340 Registered: Apr-07
| Posted on Wednesday, May 07, 2008 - 03:02 pm: |
I've heard both and honestly been more impressed with the type-x. Especially for the price. Maybe the setup just wasn't that great on the JL w7s (12s and 13.5) I've heard, but there are other drivers I would prefer- If you want to have a recognizable sub people will say 'damn that costs a lot' then get the JL. |
Cincinnati,
2-D615D4 Dia...
Post Number: 322 Registered: Feb-08
| Posted on Wednesday, May 07, 2008 - 03:23 pm: |
troy car audio is not about the cost its about the sound and if you have heard both and the type x sounded better than thats what ill go with just need to sell my current system im going through systems like crazy |
Silver Member Username: Krazyj
Post Number: 158 Registered: Jan-06
| Posted on Wednesday, May 07, 2008 - 03:33 pm: |
what troy is trying to say is, that there are many subs that can sound good and be loud and probably for cheaper than both. He is probably assuming that because you want to pick between two well known companies that you want a product that has a name that everyone knows. but i could be wrong. |
Post Number: 361 Registered: Aug-06
| Posted on Wednesday, May 07, 2008 - 04:02 pm: |
"troy car audio is not about the cost its about the sound and if you have heard both and the type x sounded better than thats what ill go with just need to sell my current system im going through systems like crazy" "i can get deals on either one just which one is going to sound the cleanest and loudest with a 1000 rms going to it in a s-10" Based on your posts, i would suggest you buy both subs, place them into your setup and keep the one that meets your listening needs and compliments your application. Besides, you may very well change your setup even before the sub is broken in. That trend is slowly creeping into the forum....
Post Number: 1341 Registered: Apr-07
| Posted on Wednesday, May 07, 2008 - 05:04 pm: |
"that there are many subs that can sound good and be loud and probably for cheaper than both" Yes, that is what I mean. I have owned the type-x, and installed a w7 and heard several other w7 installs. The vehicle and install will make all the difference, people will argue which one sounds better all day (except that most haven't heard the type-x), but I was happy with the SQ of my alpine type-x 12. I have never heard a W7 as loud, but I've also never been able to build a proper enclosure for one either to do a fair comparision. I'd rather have a Fi Q (or several other subs for that matter, but this is a w7 v X thread) over the type-x. |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5744 Registered: Feb-06
| Posted on Wednesday, May 07, 2008 - 08:35 pm: |
W7 owns the Type X. |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 498 Registered: Sep-07
| Posted on Wednesday, May 07, 2008 - 08:52 pm: |
W7 Resale value when you get bored with it. |
Gold Member Username: Jakeyplaysbass
St. Louis,
MO / ASU
Post Number: 2691 Registered: Jul-05
| Posted on Wednesday, May 07, 2008 - 09:11 pm: |
The Alpine Xs are straight SQ subs. Very accurate, but dont get very loud. W7s are more on the SQL side. Personally i wouldnt get either of them but depending on what you want make your decision. Brian is right about the W7 tho, it resells very easily. |
