Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > Amp is cutting in and out
Author Thread: Amp is cutting in and out
Username: Dubmc23
Rapid City, SD
Post Number: 253
are there any problems any where besides the amp that i can check or is that a sign of a fried amp?
Username: Moey_g
Sydney
Australia
Post Number: 238
Maybe impedance is too low, power wire too small, bad ground. Can be many different problems.
What amp and what sub/speakers you using and how many. Do you know the voice coil configs on the sub(s) and the amps minimum impedance?
How big is the power wire?
Do you have a good ground connection and is the ground cable the same size or bigger that the power wire?
Username: Dubmc23
Rapid City, SD
Post Number: 254
ok i think its probably a bad ground...thanks for all the help...
Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > Amp is cutting in and out [ « Previous ] [ Next » ]
