Home > Message Board > Car Audio > Head Units > Archive through August 01, 2008 > Blown head unit?
Author Thread: Blown head unit?
Username: Slimanus69
Naugacktu, Ct
United states
hi i recently hooked up my head unit and it was working fine for a couple of hours maybe 5 or so then i discounted it and reconected it and it worked for about 2 mins and then stoped. this was only my second time hooking up a head unit and i spliced the wires to match. do you think i hooked it up wrong and ruined it? now it wont even power up when i try to hook it up.
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1195
i think a splice came done or you blew the ffuseon the back of the headunit, now a days it's near impossible to blow a radio theres is alot of fusing to prevent it. recheck your fuses and power/acc feeds.
Username: Clethal70
Post Number: 32
Most likely one of those power wires might have touched metal of your car and blown a fuse in the car if not your fuse on your radio.
Home > Message Board > Car Audio > Head Units > Archive through August 01, 2008 > Blown head unit? [ « Previous ] [ Next » ]
