Thread: NeeD hELp |
Silver Member Username: Dloc
WHITTIER,
CA
Post Number: 132 Registered: Jul-06
| Posted on Tuesday, May 06, 2008 - 02:11 am: |
i was thinking of buying four L7 15s....is there any other type of woofer out there that might cost the same but yet be a bit better if so let me know |
Gold Member Username: Killerzracing71
Post Number: 2158 Registered: Aug-05
| Posted on Tuesday, May 06, 2008 - 02:58 am: |
Theres alot better then those whats your Budget and what kinda vehicle do you have is it stock electricall are you willing to upgrade in the future and how much space do you have to work with |
Gold Member Username: Andrew571
Stillwater/Edmond,
Oklahoma
Post Number: 1782 Registered: Oct-05
| Posted on Tuesday, May 06, 2008 - 04:12 am: |
nope. L7s are the best out there. period. |
Gold Member Username: Insearchofbass
Post Number: 9148 Registered: Jun-04
| Posted on Tuesday, May 06, 2008 - 07:46 am: |
"nope. L7s are the best out there. period." hes joking...in case you didnt know |
WHITTIER,
CA
Post Number: 134 Registered: Jul-06
| Posted on Tuesday, May 06, 2008 - 03:40 pm: |
its going on a expedition..i am going to upgrade the elictical soon....my budget is about 180 220 a speaker |
Gold Member Username: Tejcurrent
Post Number: 1334 Registered: Apr-07
| Posted on Tuesday, May 06, 2008 - 03:44 pm: |
I'd do the electrical first to protect your equipment. |
Gold Member Username: Shortysetnies
Rock Vegas,
NC
US
Post Number: 2558 Registered: Mar-06
| Posted on Tuesday, May 06, 2008 - 03:57 pm: |
yeah, electrical needs to be done before you start powering your equipment. whats your budget for everything? amps, subs, wire, elec., HU, box... |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5701 Registered: Feb-06
| Posted on Tuesday, May 06, 2008 - 04:43 pm: |
you need a HO alternator, big 3, and at least 1 battery in the back to run 3000+ watts. L7s will be the loudest for the money, but there are speakers that sound a lot better and get almost as loud for the same money. |
WHITTIER,
CA
Post Number: 135 Registered: Jul-06
| Posted on Tuesday, May 06, 2008 - 04:48 pm: |
reece what speakers would those be.....al i need is the alternator and the battery for the back |
Silver Member Username: Surferdude9371
Im BTL Bumpin
Post Number: 891 Registered: Mar-07
| Posted on Tuesday, May 06, 2008 - 06:28 pm: |
cvr's? im not a big fan of the square woofer in my opinion it doesnt sound just right but im sure someone will call me out on that lol i had the solo x 18. |
Platinum Member Username: Rovin
1 15 = 149.1DBs Trinidad & T...
Post Number: 13713 Registered: Jul-05
| Posted on Tuesday, May 06, 2008 - 08:53 pm: |
how about 4 Fi SSD 15" - $209 each ... |
Post Number: 1336 Registered: Apr-07
| Posted on Tuesday, May 06, 2008 - 09:36 pm: |
Very nice subs, but from my understanding the L7s will have a bit more output (at the cost of sq of course, it just depends on the goals). |
