Thread: Replacement suggestions |
Bronze Member Username: Slimdog53185
Bowling Green,
Kentucky
U.S.
Post Number: 79 Registered: May-07
| Posted on Monday, May 05, 2008 - 08:17 pm: |
I'm looking to replace my 2 12" Power Acoustik MoFo's. I will probably be keeping the same amp for a while. It's a MA Audio HK-598. What I'm looking for is some $200 12"s that will be just as loud if not louder and have better sq. I have a 2000 stratus so Space is kinda an issue. |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5690 Registered: Feb-06
| Posted on Monday, May 05, 2008 - 08:33 pm: |
2 12s for 200 bucks? good luck. the best i can think of would be two audioque sdc2.5s, but you would be underpowering them. that amp you have is crap though. you should definitely get a new one. just save up money and do it right the first time. it will save you money in the long run. |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 856 Registered: Aug-07
| Posted on Monday, May 05, 2008 - 11:10 pm: |
^^what he said |
Bowling Green,
Kentucky
U.S.
Post Number: 80 Registered: May-07
| Posted on Tuesday, May 06, 2008 - 01:03 am: |
I mean $200 each. Sorry. |
Bowling Green,
Kentucky
U.S.
Post Number: 81 Registered: May-07
| Posted on Thursday, May 08, 2008 - 12:54 pm: |
No one has any suggestions? |
Bowling Green,
Kentucky
U.S.
Post Number: 82 Registered: May-07
| Posted on Saturday, May 10, 2008 - 01:20 pm: |
Would anyone like to recommend an amp then? I really planned on upgrading it first anyway. I would like a good budget amp though nothing real expensive. I need 2400w at 2 ohm for the mofo's. |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6375 Registered: Mar-04
| Posted on Saturday, May 10, 2008 - 02:37 pm: |
2 Phoenix Gold RSd12's would sound very nice on that amp. They are reasonably inexpensive too. |
Gold Member Username: 04redmach1
Lagrange,
GA
Post Number: 1872 Registered: Mar-06
| Posted on Saturday, May 10, 2008 - 02:44 pm: |
You need to sell your setup locally, then come back for help. You can have the biggest sub in the world, but with a crappy amp, you got nothing. Are your subs Dual 2 or 4 ohm? Kevin |
Bowling Green,
Kentucky
U.S.
Post Number: 83 Registered: May-07
| Posted on Saturday, May 10, 2008 - 10:27 pm: |
dual 2 ohm. |
