Thread: Building box question |
Silver Member Username: Icecreamman5687
Post Number: 152 Registered: May-06
| Posted on Monday, May 05, 2008 - 06:06 pm: |
ok so im really new at building boxes and i know i probley messed up0 but i built a sealed box for 2 12 in type r's. i made it to spec of what the subs are for and i seeled all the joints with silicon and i used wood screws all over it. it has blown apart on me and ever snapped some of the screws and this is the second time.. any idea on what it might be. |
Gold Member Username: Nyyfan13
15 MAG
Post Number: 9519 Registered: Jul-06
| Posted on Monday, May 05, 2008 - 06:08 pm: |
Did you use 3/4" mdf? |
Silver Member Username: Explictx
Glen Burnie,
Maryland
Post Number: 576 Registered: Mar-07
| Posted on Monday, May 05, 2008 - 06:17 pm: |
Dont forget wood glue. |
Post Number: 153 Registered: May-06
| Posted on Monday, May 05, 2008 - 06:51 pm: |
I USED 3/4 IN MDF BUT NO WOOD GLUE. THE WOOD IS OK IT JUST BREAKIN ALL MY SCREWS AND PUSHING THE WOOD APART |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16475 Registered: Jun-06
| Posted on Monday, May 05, 2008 - 07:32 pm: |
Didn't see this thread. Responded in the other one. |
Gold Member Username: Andrew571
Stillwater/Edmond,
Oklahoma
Post Number: 1781 Registered: Oct-05
| Posted on Monday, May 05, 2008 - 07:44 pm: |
Yep the glue is your problem. Its okay... you tried. Now you know how to do it right. Wood Glue all the joints (both peices) and clamp them together while u screw them right. Do this will all your joints and when its all dry, THEN you silicon the joints and all is well |
Post Number: 154 Registered: May-06
| Posted on Monday, May 05, 2008 - 08:38 pm: |
ok man thnx. ill go try that |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5695 Registered: Feb-06
| Posted on Monday, May 05, 2008 - 08:45 pm: |
if the box is flexing enough to tear apart you might want to double baffle everywhere too. |
