Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > Building box question
Author Thread: Building box question
Username: Icecreamman5687
Post Number: 151
ok so im really new at building boxes and i know i probley messed up0 but i built a sealed box for 2 12 in type r's. i made it to spec of what the subs are for and i seeled all the joints with silicon and i used wood screws all over it. it has blown apart on me and ever snapped some of the screws and this is the second time.. any idea on what it might be.
A pic is worth
1000 posts!!
Post Number: 16474
Did you pre drill your holes? What size screws did you use?
Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > Building box question [ « Previous ] [ Next » ]
