Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > Back on E.
Author Thread: Back on E.
Username: Krazyj
Post Number: 151
its been a while since i have been on ecoustics. most of you probably don't remember my short career on the site but i do remember being one of the only girls. but besides the point. I need to put together a budget system. Subs,amps,coax speakers,wires,etc 97 altima. SQ setup. budget is $1000
Username: Redliner
Wilmington, Ma
Post Number: 4368
well welcome back id say try to find some w6v2's a cheap amp idk and some infinity kappa's
Username: Peakohm
Post Number: 63
^^agreed with that setup. nice setup/price
Username: Ctmike
Ct.
Post Number: 6063
you can start with buying my 15" aa atlas cheap:-)
and welcome back.
A pic is worth
1000 posts!!
Post Number: 16471
I'll throw out there my 10" RL-i10 and Kicker ZX500.1 combo for $450 shipped. I can even throw in power wire, stinger in-line fuse holder and 60 amp fuses for less than I paid. Everything brand new.
That would at least take care of the bass, which can be/is the most expensive side of car audio.
Just throwing it out there.
Username: Jkidder
Worlds gunna end, In
2012
Post Number: 3520
components are way more expensive than subwoofers...
the cisco kid
A pic is worth
1000 posts!!
Post Number: 16472
Not necessarily the amps that drive them tho.
You can spend too much on just about anything these days.
Username: Joebruce
Mach5Audio M...
Post Number: 2057
Ok here is a very nice budget system. I didnt include a HU since you didnt say you needed one. Total is about $920 plus shipping on the stuff so you'll be around $1000 with shipping.
5.25 Components(find some adaptor brackets to fit them)
http://www.sonicelectronix.com/item_10495_DLS+Reference+RS5+-+RS5A.html
Sub
http://www.sonicelectronix.com/item_3646_Infinity+Kappa+Perfect+12d+VQ.html
Amp
http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=ra30
Wire
http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-K4
You will need a subwoofer box which you can build yourself or find a prefab sealed one for the sub. If you dont want to run components then here are some nice coaxials
http://www.sonicelectronix.com/item_10498_DLS+Classic+425.html
You can probly find everything cheaper on ebay.
Username: Joebruce
Mach5Audio M...
Post Number: 2058
If you dont want to get adaptor brackets to run 5.25 speakers then I would get these
http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=457
Do you need a HU or do you have one?
Username: Krazyj
Post Number: 152
i currently have: and eclipse 5425(old model)so i dont need a head unit. im going to take a look at your links.
Username: Mmaudioconcepts
Post Number: 485
go with
alpine type R 15"
alpine type R 5x7 and 6x9 coax
just need amps to push them
Username: Krazyj
Post Number: 153
is the type R sub considered to be SQ
Username: Surferdude9371
Im BTL Bumpin
Post Number: 888
if i were you id throw that whole grand into either mids or subs and save up for the rest better to get the best from the start
Username: Ctmike
Ct.
Post Number: 6065
type r is more sql. every sub mentioned here has better sq than the r.
Username: Joebruce
Mach5Audio M...
Post Number: 2063
"go with
alpine type R 15"
alpine type R 5x7 and 6x9 coax"
No way, the links I posted are by far better than that. If you want a decent SQ system your front stage should be the biggest concern. The DLS components sound awesome. If you can use ebay then go with the DLS MS6A components,you can get them cheap there.
Username: Talon01
Team Revolution , Pa
Usa
Post Number: 1238
type r is a sql sub. the dls will be a great component set for you
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5723
if you want a 10 go with pauls Rl-i. it will rock your world.
Username: Tejcurrent
Post Number: 1337
I would focus on good equipment for the front, and sound deadener. Pauls setup will be good for bass, but again focus on the front.
http://cgi.ebay.com/NEW-KICKER-ZX350-4-4-2-CHANNEL-AMPLIFIER-CAR-AUDIO-AMP_W0QQi temZ350055842126QQihZ022QQcategoryZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
150 shipped
That will power an active 2 way setup well, or even just drop-in replacements of the speakers you have. I would try to get a good set of 6.5 components.
http://cgi.ebay.com/Focal-Polyglass-165-VR-6-5-2Way-Component-165-V2S-NEW_W0QQit emZ170216480527QQihZ007QQcategoryZ18800QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
would be a good replacement (I'd get a bracket made to fit these, they are 300 shipped I believe.
So around 450 on your front stage.
http://cgi.ebay.com/DLS-UR6S-6-5-2-WAY-COMPONENT-SPEAKERS-ULTIMATE-NEW-06_W0QQit emZ250243100572QQihZ015QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Those would make it 500 on the front stage.
You could buy pauls sub setup, to finish out the substage. That would leave you with about 100 for wiring, but if you really want sq then you should dump another few hundred in sound deadener. You could easily find cheaper speakers you would be happy with- you just have to listen to things and find what you like.
Personally I didn't like my infinity Kappas- they were way too bright. Just my thoughts on them though.
Post Number: 1338
The type-rs sound pretty good, I prefered the type-x in a sealed enclosure if you have to go alpine. Not my first pick, and again personally I'd go with the rli deal with your budget and the real importance of a sub to your overall sq.
Username: Redliner
Wilmington, Ma
Post Number: 4376
ya great price on paul's stuff and a great guy to deal with id jump all over that
Username: Shortysetnies
Rock Vegas, NC
US
Post Number: 2564
Paul, I think you need to hold onto that until I go into the academy in July so I can get it. That sounds like EXACTLY what I want for my truck!
Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > Back on E. [ « Previous ] [ Next » ]
