Thread: How to figure out imp. rise |
Gold Member Username: Cblaze
Rock island,
Tenesssee
Us
Post Number: 2058 Registered: Sep-07
| Posted on Monday, May 05, 2008 - 10:48 am: |
wanna know where i can figure out if i can wire 2 dual 2 ohm subs to my 1606d.with out smoking it |
Bronze Member Username: Peakohm
Post Number: 62 Registered: Apr-08
| Posted on Monday, May 05, 2008 - 12:53 pm: |
if you wire the coils in parallel and subs in series you'd get 2 ohms. there are other options but just a quick glance that looks like the way you'd get max power without killing the amp |
Gold Member Username: Nyyfan13
15 MAG
Post Number: 9518 Registered: Jul-06
| Posted on Monday, May 05, 2008 - 01:30 pm: |
You have the option of .5 ohm or 2 ohms or 8 ohms....Don't run that amp at .5 ohm.....run it at 2 ohms. What subs do you have? |
Rock island,
Tenesssee
Us
Post Number: 2060 Registered: Sep-07
| Posted on Monday, May 05, 2008 - 02:28 pm: |
right now 1 sx thankin about adding one more.guess if i do ill just get a second amp |
Diamond Member Username: Bestmankind
Post Number: 20692 Registered: Oct-05
| Posted on Monday, May 05, 2008 - 03:00 pm: |
if you add another sx then get the kicker kx2500.1. you can find one at a good price on ebay and it is 2ohm stable so it would be perfect for 2 sx's. |
