Thread: Help plz |
Silver Member Username: Kingtutus
Lincoln,
Nebraska
U.s.a
Post Number: 275 Registered: Dec-07
| Posted on Monday, May 05, 2008 - 09:21 am: |
i have a 12" pyle and when i play it it makes a kind of scratching/ clicking noise cant figure out y it dont scratch when u push on it i have turned gain down no bass boost. can u plz help |
Silver Member Username: Prozack52
Cincinnati,
2-D615D4 Dia...
Post Number: 315 Registered: Feb-08
| Posted on Monday, May 05, 2008 - 09:47 am: |
take the sub out and see if the wires hooked up to the voice coils are hitting the cone when it bumps thats happened to me before |
Lincoln,
Nebraska
U.s.a
Post Number: 276 Registered: Dec-07
| Posted on Monday, May 05, 2008 - 09:50 am: |
it is only one vc |
Cincinnati,
2-D615D4 Dia...
Post Number: 316 Registered: Feb-08
| Posted on Monday, May 05, 2008 - 09:55 am: |
ok thats fine but what im sayin is the wires running to the vc make be hitting the back of the sub when it bumps its happened to me |
Lincoln,
Nebraska
U.s.a
Post Number: 277 Registered: Dec-07
| Posted on Monday, May 05, 2008 - 09:57 am: |
ill check it out when i get a sec i am @ school and if is that how would u fix that |
Cincinnati,
2-D615D4 Dia...
Post Number: 317 Registered: Feb-08
| Posted on Monday, May 05, 2008 - 10:01 am: |
if thats it your e prolly to long from amp to sub so when your putting the sub in the box the wires has a lot of slack in it allowing it to move around or be pushed up against the cone of speaker so shorten the wire |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16470 Registered: Jun-06
| Posted on Monday, May 05, 2008 - 12:55 pm: |
It's a $20-$30 sub. Possibilities are endless. Leave it hooked up and play it free air (out of the box). Does it still scratch? |
Lincoln,
Nebraska
U.s.a
Post Number: 278 Registered: Dec-07
| Posted on Monday, May 05, 2008 - 11:32 pm: |
it was blown i took a dmm the vc and it read like 10ohms for a 4ohm sub is is not good |
