Home > Message Board > Car Audio > Amplifiers > Amp for alpine type r
Author Thread: Amp for alpine type r
Username: Speckto
I know this has been covered a little but couldnt find a good answer... I have one 12" alpine type R SWR 1242D
What would be a good amp to run this sub?
Relevant Product Info
Username: Dirtrider125
Post Number: 86
i have a audiobahn dub2502 for sale it does 500 rms bridged and i have a 12" type r also and it makes it hit hard its a good amp only $50 shipped.
Username: Drant19
DUB-C, TX
Post Number: 853
get something that will put 800wrms on it
Username: Fritos2
Post Number: 11
isnt it bad for it to have more rms than it recommends?
Username: Icecreamman5687
Post Number: 155
on the type r's i have ran them and they are power hungry subs.. it wont hurt to go more rms than what they say. ive put up to 1100 watt rms to one. so really choose what you want to sound. and how hard u want it to hit
Username: Drant19
DUB-C, TX
Post Number: 855
1000wrms is alot for a type-r. the most i would put on one is 1000rms. my friend has a 12"type-r on a kicker zx750.1, and it gets pretty loud
Username: Speckto
would a alpine mrp-m850 be a pretty good choice?
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 491
Do you have a $300 budget?
Username: Rovin
1 15 = 149.1DBs
Trinidad & T...
Post Number: 13716
they are not power hungry but i suggest a good clean 600wrms @ 2ohms amp would be good
like
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17702
even though it 800wrms that'll be fine ...
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5323
jbl gto 601.1 etc lot of amps
Username: Speckto
Im looking to spend under 200 if possible
Username: Ctmike
Ct.
Post Number: 6092
cadence txa1000d would do then. i run one with no complaints, and $199 shipped from cadence with 2 year warrenty is pretty good.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > Amp for alpine type r [ « Previous ] [ Next » ]
