Thread: Should i put a 12" type r in a sealed or ported box |
Bronze Member Username: Dirtrider125
Post Number: 78 Registered: Apr-07
| Posted on Sunday, May 04, 2008 - 03:51 pm: |
i already have a sealed box but cant decide if i should get a ported one. i will be powering it with a kx450.2 500 rms briged so it will be getting full amount of power. i want it to be loud but still sound good |
Gold Member Username: Ctmike
Ct.
Post Number: 6054 Registered: Feb-06
| Posted on Sunday, May 04, 2008 - 04:07 pm: |
ported, anywhere from 32-35hz. works best for them imo. |
Silver Member Username: Hittin1
LakeCharles LA.,
La
Post Number: 278 Registered: May-07
| Posted on Sunday, May 04, 2008 - 04:48 pm: |
x2^^^^ |
Post Number: 97 Registered: Apr-07
| Posted on Monday, May 05, 2008 - 02:17 pm: |
can someone make me a box tuned to 32 hz and i will pay u |
Ct.
Post Number: 6062 Registered: Feb-06
| Posted on Monday, May 05, 2008 - 02:23 pm: |
bj (fisher customs): bj@fishercustoms.com or phil (woodlawn cabinetry) www.woodlawncabinetry.com both great quality, and very good c.s. either way you can't lose. |
Silver Member Username: Surferdude9371
Im BTL Bumpin
Post Number: 884 Registered: Mar-07
| Posted on Monday, May 05, 2008 - 02:31 pm: |
^both great box builders |
Gold Member Username: Joebruce
Mach5Audio M...
Post Number: 2056 Registered: May-04
| Posted on Monday, May 05, 2008 - 04:25 pm: |
I would go ported. Although when I had my Type-Rs I had them in a sealed box and they sounded nice and got pretty loud. Maybe try out your sealed box while youre having a ported one built and see how you like it then try out the ported and use whichever you like best. Oh and Fishercustoms FTW!! |
