Thread: Blown Orion H2, what should I replace it with? |
New member Username: Jamon
Post Number: 1 Registered: May-08
| Posted on Sunday, May 04, 2008 - 02:16 am: |
I think I hurt my Orion H2. I think the voice coil is rubbing. Since the H2 is no longer made, and I can't readily find a replacement, I was wondering what comparable speakers exist. I have an orion D2400 amp, and I will probably be placing the sub in a bandpass box. I want something that is really close to as loud as the H2. I generally play 90s era bass music on the system. Any recommendations (Along with price) would be appreciated. |
Post Number: 2 Registered: May-08
| Posted on Sunday, May 04, 2008 - 02:20 am: |
It is a single 12" |
Gold Member Username: Jakeyplaysbass
St. Louis,
MO / ASU
Post Number: 2673 Registered: Jul-05
| Posted on Sunday, May 04, 2008 - 02:44 am: |
Audiopulse Axis 12, Audiopulse.com. Contact Mike at Exigeaudio.com for better prices. Also bandpass boxes are not the way to go. You can save space and get a much better sound off a ported box. I would build a 2cuft box tuned to 32hz for the 12. |
Post Number: 3 Registered: May-08
| Posted on Sunday, May 04, 2008 - 08:40 am: |
I guess I could consider a basic ported box. I'll be ripping up the box anyway. If I do a ported box I'll probably need to stick with a sub that is less than 9" deep. I did check out the AudioPulse Axis 12 and that does seem pretty much like the H2. Any other suggestions? |
Gold Member Username: Hdubb
Team Revolution
Post Number: 3613 Registered: Nov-04
| Posted on Sunday, May 04, 2008 - 09:51 am: |
you have pics of your h2? eh how much power do you have? what;s you;'overall goal? spl,sq,sql lamfcal's?(loud a.ss ma fu.ckin crazy a.ss lows) |
Post Number: 4 Registered: May-08
| Posted on Sunday, May 04, 2008 - 11:41 am: |
I'll post the pics later. I took apart the sub, and the voice coil had come apart. Heat had damaged and warped the Aluminun former. I really thought I didn't actually have the power to damage that sub. I have an orion D2400. I'm running only one sub. My goal is to have really solid 30 to 60 Hz bass for old school street bass music. I have no interest in audio competition. |
Platinum Member Username: Rovin
1 15 = 149.1DBs Trinidad & T...
Post Number: 13709 Registered: Jul-05
| Posted on Monday, May 05, 2008 - 12:51 pm: |
id say a RE SX or FI Bl ..... |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6356 Registered: Mar-04
| Posted on Monday, May 05, 2008 - 01:15 pm: |
Jamon, If you killed an Orion H2 12" w/ a D2400, you were clipping the F#CK out of that amp. What ever sub you get next, turn that gain/bass boost down! You may also want to look into a pair of 10's, maybe Fi SSd's. Forget the bandpass box, go w/ a nice ported box tuned low. As for a comparable sub. And RE SX on that amp would be a good match. |
Gold Member Username: Talon01
Team Revolution ,
Pa
Usa
Post Number: 1235 Registered: Jun-07
how do you feel about a rd alpha 12, i have one for a good price |
Gold Member Username: Extrmndor3
Http://illuzonemu.serv...,
^^^Sick Game
Post Number: 7911 Registered: Feb-06
| Posted on Monday, May 05, 2008 - 02:58 pm: |
that sub is hard to blow except if u have a powerplant... u were clipping that sub so bad that u blew it |
Bronze Member Username: 4realadeala
Tampa,
Florida
Post Number: 33 Registered: Mar-08
| Posted on Monday, May 05, 2008 - 05:23 pm: |
90's era bass music heh. Does anybody remember DJ Magic Mike? What about Two Live Crew? |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5686 Registered: Feb-06
| Posted on Monday, May 05, 2008 - 06:09 pm: |
well considering the d2400 only does 1200 watts i don't think you have the power for an axis and they only make the revo in dual 2 so I would probably go with an incriminator audio death penalty. you can find them on www.soundsolutionsaudio.com |
