Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Help with duel amps
Author Thread: Help with duel amps
Username: Dohcgarrett_t3
Anchorage, Alaska
United States
I have 2 rockford fosgate 301m amps (mono) and 2 kicker soloberic 12" l7 @ 2 ohm
how do i wire them so that they dont sound like crap? tried wireing them and they sounded like crap i cant find any wiring diagrams for the way i want to wire them.
Relevant Product Info
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5322
you need to install both amps... then wire your sub at 4 ohms (series).
I think you'll be better buying a newer amp such as kicker zx 1500.1
Username: Mmaudioconcepts
Post Number: 484
are they dual or single voice coils subs? Those amps only put out around half the power that would need for an L7. They would have to be dual 4ohm subs just to get that power. also there are many factors tht play into the subs sounding good. The box has to be right, the setting on the amp.,the headunit ,the power from the amp. etc.
Anchorage, Alaska
United States
the L7's are DVC 2 ohm 750 rms
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Help with duel amps [ « Previous ] [ Next » ]
