Thread: Making box for 12" type r how big should the hole cutout be |
Bronze Member Username: Dirtrider125
Post Number: 70 Registered: Apr-07
| Posted on Saturday, May 03, 2008 - 06:02 pm: |
how big is the cutout supposed to be where you put the sub in its a 12" |
Post Number: 72 Registered: Apr-07
| Posted on Saturday, May 03, 2008 - 06:23 pm: |
its going in a 0.85 cubic foot sealed box powered by a kicker kx450.2 gettin 500 rms how will that sound good or should i get a ported box |
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
Post Number: 136 Registered: Mar-08
| Posted on Monday, May 05, 2008 - 11:17 pm: |
flip the speaker over on the box and trace around it, drill a hole in the middle of the circle on the wood that you traced. cut it out with a jigsaw and stay about 3/4 of an inch INSIDE the circle. trim where needed. |
Fort Valley,
GA
Post Number: 137 Registered: Mar-08
it no rocket science. |
Gold Member Username: Nyyfan13
15 MAG
Post Number: 9523 Registered: Jul-06
| Posted on Monday, May 05, 2008 - 11:23 pm: |
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=520&i=500SWR1222&tp=111& tab=features_and_specs |
Silver Member Username: Dsmith07
NC
Http://com4....
Post Number: 799 Registered: Jun-06
| Posted on Monday, May 12, 2008 - 12:16 pm: |
10 13/16" |
