Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > OT: cd burning
Author Thread: OT: cd burning
Username: Rds2oo8
MN
Post Number: 232
i wana make a cd with mp3 songs off limewire but im tired of just getting like 16-20 on a cd i was wondering how u can get more on 1 cd cuz my bro in law got like 45 on a cd i wana know how he did it?
Username: Peakohm
Post Number: 48
pretty much any software program out today, you just need to burn it as an mp3 disc and not an audio disc. what do you have now? nero works great for me, i think it's called a jukebox cd under nero where you can add mp3 and wma.
Username: Rds2oo8
MN
Post Number: 233
oic right now all i do is save it on lime wire then burn it with windows media player is nero free and what kind would be easiest to use?
Username: Peakohm
Post Number: 49
nero isn't free but you can find it free ;)
from what i know i don't think there is a way to burn an mp3 disc in windows media player.
i know some people who use roxio and some other programs too, but nero's my fav.
Username: Peakohm
Post Number: 50
http://www.nero.com/enu/downloads-nero8-trial.php
there's a link to the 15 day trial of nero.
Username: Rds2oo8
MN
Post Number: 235
alright thanks im downloading it now i hope 2 get a system soon like by the end of summer im hopen lol 15" RE SX on a audioque 1200 watt amp in a 02 buick lesabre
Username: Peakohm
Post Number: 51
yea no prob. bring it up and you should just have to nero start smart, when that comes up go to the music icon, then there should be an option to create jukebox cd with mp3, wma, mp4 as in parenthesis. click on that and add 'em and burn
Username: Rds2oo8
MN
Post Number: 236
ight i gota restart my comp
Username: The_image_dynamic
San Diego, California
Post Number: 3926
And some serials for that trial:
1K22-0867-0795-66M4-5123-8911-KC01
1K22-0867-0795-66M4-5269-0233-5337
1K22-0867-0795-66M4-5549-7964-3032
1. install nero without the toolbar
2. you can install full but i customize the installation
3. install it with the demo key dont use yet the keygen
4. after installation u are prompt to restart, select no.
5. go to "Start -> All Programs -> Nero 8 -> Nero Toolkit -> Nero Control Center"
6. uncheck the always check update
7. now go License and use the CIM keygen but be sure to delete the demo key.
8. delete the PatentActivation.exe in the "C:\Program Files\Common Files\Nero\Shared\NL3: folder
9. the patentactivation will still pop up, just fill up its form then activate. now it will be activated.
10. now u can enjoy the full version ultra ed nero. even if u restart ur pc.
A pic is worth
1000 posts!!
Post Number: 16425
Fug. And I paid $100 for my version.
Where have you been all my life Brad?
Username: Rds2oo8
MN
Post Number: 237
the serial # dont work it says there incorrect
Post Number: 3927
Ok here is the keygen (scanned: clean)
http://www.sendspace.com/file/izgsi9
Username: Rds2oo8
MN
Post Number: 238
ight ill c if it works when i download nero it says i need 2 download direct x9.0 n evertime i do it says it dont have it?
Username: Hittin1
LakeCharles LA., La
Post Number: 271
You can burn a Mp3 disk w/ WMP 11. It is called data disk.. You only have to change one setting.
Username: Rds2oo8
MN
Post Number: 239
when i put the CD-R into the comp it says audio cd in like gray so i cant change it to a data cd =[
Username: Hittin1
LakeCharles LA., La
Post Number: 275
are you using WMP 11?
Username: Hittin1
LakeCharles LA., La
Post Number: 276
1-open wmp 11.
2-maximize screen
3-move cursor to little arrow under the word Burn and click on the arrow. (the arrow appears when cursor is moved under the word BURN- this accesses the options)
4- move dot that is by audio cd to data cd(right underneath it.)
Username: Rds2oo8
MN
Post Number: 241
it wont play in my cd player ugh this is frustrating but i got work at 12-4 so ill bb on a lil after 4 most likley
Username: Thumpinwith8s
2 RE8s,PG Xenon 400.1, 135.5dbs!!!!
Post Number: 1105
yes! a keygen for Nero....now I can burn DVD's again....wooot!
Username: Lms
Do any of you guys have a product key for microsoft word 2007or microsoft office 2007? my trial version has expired _ thanks
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1179
lms i would but this isn't a piracy forum but look iy up on astalavista.com, crack.cd or crackspider.net. just remember the sites are riddled with viruses so don't run an tthing that looks weird like any run . exexs avoid. never say yes to any pop ups ether.
Username: Lms
thanks bro lol
Username: Rds2oo8
MN
Post Number: 244
the cd doesnt work in my cd player when i change it to a data cd =[ it just says it has 1 song on it for 33 mins?
Username: Stateprop486
PA
Post Number: 1493
burning an mp3 cd is useless if your cd player doesn't play mp3 cds. im guessing your cd player doesnt have the MP3 capability. what HU is it?
Username: Hittin1
LakeCharles LA., La
Post Number: 277
if your HU doesn't say mp3 on it somewhere then you cant play a mp3 disk. You can get a "decent" one for about $119 or so..
Home > Message Board > Car Audio > Subwoofers > Archive through May 08, 2008 > OT: cd burning [ « Previous ] [ Next » ]
