Thread: Help me decide. So many choices |
Gold Member Username: Jtown
Team RD,
Texas
Post Number: 2830 Registered: Mar-07
| Posted on Thursday, May 01, 2008 - 07:05 pm: |
Well I've had my alpha for about a year now and decided I want to try something new, as well I enjoy building boxes and this will be a chance to do a sort of "custom/show" box. I was thinking of a 15" but they really just take up a lot of space. So I'm really looking into either a single or dual 10" setup. I don't want to pay much more than $300 for a pair, so if you have any other suggestions, feel free. Right now I'm looking at a pair of Image Dynamic ID10s, a pair of SDC2.5s, a single HDC3, SSA Icon. I was really set on the IDs, but now I'm unsure. I have 1000wrms at 1 ohm (RD1000.1) that I will be using, nothing more. I want SQL. the box will be ported, tuned to 34hz probably (max). Thanks in advance. |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 479 Registered: Sep-07
| Posted on Thursday, May 01, 2008 - 07:07 pm: |
Audioque SD 2.5s seem to get good reviews. Not sure about the lows though. |
Diamond Member Username: Bestmankind
Los Angeles,
CA
Post Number: 20654 Registered: Oct-05
| Posted on Thursday, May 01, 2008 - 08:03 pm: |
i really like the image dynamics. |
Los Angeles,
CA
Post Number: 20655 Registered: Oct-05
| Posted on Thursday, May 01, 2008 - 08:12 pm: |
i really think a pair of sound splinter rl-i 10s would be a good choice for you. it would get loud and clean. i know its a bit over your budget but just look at it. it looks awesome. lol.
Team RD,
Texas
Post Number: 2831 Registered: Mar-07
| Posted on Thursday, May 01, 2008 - 08:17 pm: |
thanks guys, yeah I was wondering about those, i'll check em on the soundsplinter website and see what they can do for me any other suggestions? |
Los Angeles,
CA
Post Number: 20656 Registered: Oct-05
| Posted on Thursday, May 01, 2008 - 08:19 pm: |
how about a pair of treo tsx's? http://www.treoonline.com/tsx.html |
Team RD,
Texas
Post Number: 2832 Registered: Mar-07
| Posted on Thursday, May 01, 2008 - 08:23 pm: |
I've only heard bad things about their CS,I think I've dealt with poor CS enough to last me  |
New member Username: Harry_breuk
Post Number: 1 Registered: May-08
| Posted on Thursday, May 01, 2008 - 08:37 pm: |
I have a gmi pro 2125 watt amp powering dual 10 inch mtx subs and asingle 10 inch mtx punch sub plus a 10 inch acoustic profile passive sub the signal to the amp is fed by the sub out my 500 watt jvc receiver it sounds great until at loud passages then the gmi shuts down temporarily and then resets is this because the subs are 4 ohms the amp is rated stable at 4 ohms is there any way I can change the impedeince of the subs to 8 ohms can someone help thanks |
Gold Member Username: Mike11202
DD9515G VFL 200.1 = : ,
Sewell, NJ
US
Post Number: 1686 Registered: Nov-06
| Posted on Thursday, May 01, 2008 - 08:53 pm: |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 3873 Registered: Mar-06
| Posted on Thursday, May 01, 2008 - 09:16 pm: |
yes, yo change the subs to 8 ohms, remove the coil assembly, add a few hundreds coils of a very fine copper wire. Enlarge the hole where the coil go to accept the larger coil. re-assembly and there you go. No problem. And for a single, maybe a W7 in a HO box. |
Team RD,
Texas
Post Number: 2833 Registered: Mar-07
| Posted on Thursday, May 01, 2008 - 09:28 pm: |
gtfo of my thread, make your own. |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16404 Registered: Jun-06
| Posted on Thursday, May 01, 2008 - 09:47 pm: |
 BTW I have that sub just sitting, and sitting some more. |
Los Angeles,
CA
Post Number: 20657 Registered: Oct-05
| Posted on Thursday, May 01, 2008 - 10:06 pm: |
you can buy paul's and another one. btw paul what ohm version do you have? |
A pic is worth
1000 posts!!
Post Number: 16409 Registered: Jun-06
| Posted on Thursday, May 01, 2008 - 10:08 pm: |
Dual 4ohm. |
Los Angeles,
CA
Post Number: 20659 Registered: Oct-05
| Posted on Thursday, May 01, 2008 - 10:11 pm: |
thats perfect. if he gets another dual 4ohm sub then he can easily wire it to the amp he has. if not the sound splinter, i really like the treo tsx's also. they hit hard and sound clean. i would recomend the treo ssi's but you need a bit more power. |
Team RD,
Texas
Post Number: 2835 Registered: Mar-07
| Posted on Thursday, May 01, 2008 - 10:14 pm: |
how much paul? |
Los Angeles,
CA
Post Number: 20660 Registered: Oct-05
| Posted on Thursday, May 01, 2008 - 10:20 pm: |
paul is known for giving deals so i am sure he will hook you up. lol. paul thieves is my boi so hook him up. please. lol. |
A pic is worth
1000 posts!!
Post Number: 16411 Registered: Jun-06
| Posted on Thursday, May 01, 2008 - 10:24 pm: |
$200 shipped. The sub is crowding me lol. Never used but connected to terminal so there will be solder residue. |
A pic is worth
1000 posts!!
Post Number: 16412 Registered: Jun-06
| Posted on Thursday, May 01, 2008 - 10:26 pm: |
"paul thieves is my boi so hook him up. please. lol." Chad. Everyone is your boy lolololol. |
Los Angeles,
CA
Post Number: 20663 Registered: Oct-05
| Posted on Thursday, May 01, 2008 - 10:30 pm: |
lol paul. thats a good price paul is offering. paul never used it so its brad new and i bet mike from soundsplinter will honor the warranty even though you bought it from paul. assuming you buy the other one from sound splinter. also if you want to view more options, i found this on ebay. its a pair of treo tsx 10s in a treo prefab box. now i know what you are thinking, prefab box? well the treo prefabs are designed and tested for their subs. http://cgi.ebay.com/TREO-ENGINEERING-HOTBOX10-10-TSX-SUB-BOX-2-TSX10-44_W0QQitem Z150242501114QQihZ005QQcategoryZ32823QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Team RD,
Texas
Post Number: 2836 Registered: Mar-07
| Posted on Thursday, May 01, 2008 - 10:47 pm: |
how much are the tsxs from treo? I don't know about ordering a whole box and subs off ebay.... |
IL
Usa
Post Number: 480 Registered: Sep-07
| Posted on Thursday, May 01, 2008 - 10:50 pm: |
^ kinda takes the fun out of buying new subs... |
Los Angeles,
CA
Post Number: 20666 Registered: Oct-05
| Posted on Thursday, May 01, 2008 - 10:51 pm: |
email treo sales@treoonline.com and tell them where you live and they will provide you with dealers near by you. |
Team RD,
Texas
Post Number: 2837 Registered: Mar-07
| Posted on Thursday, May 01, 2008 - 10:53 pm: |
is their CS still as shittty as they used to be? |
Gold Member Username: 420alldaylong
Post Number: 3538 Registered: Sep-06
| Posted on Thursday, May 01, 2008 - 11:05 pm: |
Cerwin Vega V-Max Alpine Type R Orion P series Orion HP series JBL Power Series Phoenix Gold RSd RD Classic RD Sonance |
Bronze Member Username: Howtoeatapencil
Post Number: 68 Registered: Mar-08
| Posted on Thursday, May 01, 2008 - 11:10 pm: |
are you trying to get something better than the alpha, or do u just wana get something new |
Team RD,
Texas
Post Number: 2838 Registered: Mar-07
| Posted on Thursday, May 01, 2008 - 11:25 pm: |
theres not much that beats the alpha, I want something new, plus I'm trying to get away from RD... So I wouldn't be downgrading to Classics or Sonance..... |
Gold Member Username: 04redmach1
Lagrange,
GA
Post Number: 1842 Registered: Mar-06
| Posted on Friday, May 02, 2008 - 12:35 am: |
The Phoenix Gold RSD's are pretty nice subs too Kevin |
Team RD,
Texas
Post Number: 2840 Registered: Mar-07
| Posted on Friday, May 02, 2008 - 12:58 am: |
the specs on the rsds aren't exactly detailed....lol |
Gold Member Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5627 Registered: Feb-06
| Posted on Friday, May 02, 2008 - 02:29 am: |
i would say a couple of those cheap "epics" that parts express has. the ones with the silver cones were like 129 a piece or something. |
Team RD,
Texas
Post Number: 2841 Registered: Mar-07
| Posted on Friday, May 02, 2008 - 02:32 pm: |
^had trouble finding them....help? |
Los Angeles,
CA
Post Number: 20670 Registered: Oct-05
| Posted on Friday, May 02, 2008 - 02:43 pm: |
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=293-604 |
IL
Usa
Post Number: 484 Registered: Sep-07
| Posted on Friday, May 02, 2008 - 03:34 pm: |
^^ those are epics but not quite $129...lol |
Los Angeles,
CA
Post Number: 20672 Registered: Oct-05
| Posted on Friday, May 02, 2008 - 03:39 pm: |
how about a pair of JL Audio 10W3V3-4 - JL Audio 10" 600 Watt 4 Ohm Subwoofer. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5202 |
Post Number: 5630 Registered: Feb-06
| Posted on Friday, May 02, 2008 - 03:52 pm: |
yeah chad those werent the ones i was talking about. these were the same except they had aluminum instead of ti cones. |
Los Angeles,
CA
Post Number: 20674 Registered: Oct-05
| Posted on Friday, May 02, 2008 - 03:53 pm: |
yeah i figured. i couldn't find those on partsexpress so i just posted the link i found. |
Team RD,
Texas
Post Number: 2843 Registered: Mar-07
| Posted on Friday, May 02, 2008 - 04:42 pm: |
chad, thanks but.....that's over my budget lol. Plus I've already had JL great product, I just wanna try something I haven't tried yet. |
Gold Member Username: Ctmike
Ct.
Post Number: 6038 Registered: Feb-06
| Posted on Friday, May 02, 2008 - 04:44 pm: |
you can't find a link for the $129 subs cause they're sold out. they still have them posted, but status says no longer available |
Los Angeles,
CA
Post Number: 20677 Registered: Oct-05
| Posted on Friday, May 02, 2008 - 04:56 pm: |
if you want to try some realm subs, i can get them for you for a good price. http://www.realm-audio.com/products/sfID1/299/sfID2/304 |
Team RD,
Texas
Post Number: 2845 Registered: Mar-07
| Posted on Monday, May 05, 2008 - 03:00 am: |
bump |
