Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Amp not workin
Author Thread: Amp not workin
Username: Nvmyboom
Post Number: 317
my friend has amp that doesnt work, however, when he unplugs the fuse and plugs it back it the amp lights up then fads out in like 2 secs. you guys have any idea wats up?
Relevant Product Info
Username: Chaunb3400
All he does is catch t..., Alabama
U.S.
Post Number: 14208
check grounds...speaker wire connection...and all fuses
Username: Nvmyboom
Post Number: 318
i checked the ground, and all fuses, should i check the connections to the speakers inside the box?
U.S.
Post Number: 14215
yep..
Username: Teqnik
Auckland, North Shore
Auckland
The amp will go into protection mode if it detects a fault with either the speakers or the amp itself.If your speakers are ok,then it is more than likely is a fault with the amp.
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Amp not workin [ « Previous ] [ Next » ]
