Thread: JL audio 1000/1 vs. Alpine PDX 1000 amp |
New member Username: Me123456
Post Number: 8 Registered: Apr-08
| Posted on Tuesday, April 29, 2008 - 07:12 am: |
which one is better the JL audio 1000/1 amp or the alpine PDX1000watt amp? |
Gold Member Username: Ctmike
Ct.
Post Number: 6029 Registered: Feb-06
| Posted on Tuesday, April 29, 2008 - 08:31 am: |
pdx. smaller, cheaper but still great quality, stackable, imo looks better, more efficient. can't go wrong with them. |
Silver Member Username: Treez
Its not loud til it he...
Post Number: 345 Registered: Aug-06
| Posted on Tuesday, April 29, 2008 - 09:53 am: |
x2 However, the jl can take more abuse and is better quality... |
Ct.
Post Number: 6032 Registered: Feb-06
| Posted on Tuesday, April 29, 2008 - 10:36 am: |
better quality by a little imo. never heard of not one problem with the pdxs', ever. and by more abuse, as in? |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 849 Registered: Aug-07
| Posted on Tuesday, April 29, 2008 - 11:51 am: |
how can the JL take more abuse? explain.. and PDX FTW! |
Silver Member Username: Exige
Cincinnati
Post Number: 300 Registered: Nov-07
| Posted on Tuesday, April 29, 2008 - 11:11 pm: |
They're both great amps with a good reputation. You can't go wrong with either one. The PDX has the smaller footprint obviously. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5308 Registered: Dec-05
| Posted on Wednesday, April 30, 2008 - 03:47 pm: |
you should also consider price tag. |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 469 Registered: Sep-07
| Posted on Wednesday, April 30, 2008 - 05:20 pm: |
JL 1000/1 is better. Consider the kicker 1000.1 if you need 1000wmrs at 2ohms. http://www.hifisoundconnection.com/Shop/Control/Product/fp/SFV/30046/vpid/251726 6/vpcsid/0/rid/123284 Cant beat that price^^ If you need 1000wmrs at 4ohms then I would say go BIG with the JL. If you're gonna drop $400 on the Alpine, what's another $100-150?? |
Ct.
Post Number: 6036 Registered: Feb-06
| Posted on Wednesday, April 30, 2008 - 05:40 pm: |
what makes the jl so much better? |
IL
Usa
Post Number: 470 Registered: Sep-07
| Posted on Wednesday, April 30, 2008 - 06:09 pm: |
So much better? I would not drop the coin for either to be honest. The reason I would say JL over Alpine is resale value. |
Post Number: 5314 Registered: Dec-05
| Posted on Wednesday, April 30, 2008 - 07:27 pm: |
IMO i'd buy the cheapest one. |
