Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Help! 4 channel wiring
Author Thread: Help! 4 channel wiring
Username: Epcustom
I just purchased an alpine 300 watt 4 channel amp and i'm having difficulties getting two speakers and a sub hooked up. the sub is 130 rms i believe and the speakers are 75 rms each. I can get the sub to work but when i wire the speakers in they are very fuzzy and quiet. I know they work because i hooked them up to a different system and they were fine. So i think i need help with the wiring. Any suggestions would be appreciated. Thanks!
Relevant Product Info
Username: Drant19
DUB-C, TX
Post Number: 848
is the gain set?
Username: Chaosofthemasses
Edwardsburg, Michigan
Usa
this could be due to not moving the switch for frequency from low input(subs use this) to both low and high frequency(high freq is for 6x9s and such so try flipping the switch on the amp to that it may help if you wire it all together and only have it on low freq then its only gonna blast the subs and not carry signal to high frequency speakers! Hope this helps
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Help! 4 channel wiring [ « Previous ] [ Next » ]
