Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Help.Ho atlernator?
Author Thread: Help.Ho atlernator?
Username: Me123456
im getting 2 JL audio 13 w7 and 2 JL 1000/1 amps do i need a ho atlernator and what do they do?
Username: •cam•
BC
Post Number: 2456
I'd say that yes, you probably will. They can produce more current.
Username: Ebin5446
GA
the only thing on your car producing electricity is your alternator. you can get another battery or a cap or whatever but guess what thats just gonna put more strin on the alternator you have batteries etc. are just electrical storage devices they dont produce more current so if possible get a better alternator. what car are you putting this in?
Username: Me123456
im putting it in an 07 monte carlo
Username: Me123456
Post Number: 7
now if i was to get that alternator do i still need another battery to go with it?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5313
it would be ideal... You should look for IRAGGI, dbstarter, excessive amperage etc.
Considering your car is new, prices can be high.
Username: Chaosofthemasses
Edwardsburg, Michigan
Usa
Post Number: 18
a capacitor may help since it will use minimal strain on the alt since the amp wont be drawin constant power just whenever the cap draws it but if your puttin in a decent size system then the Alt would be more ideal but for peoplem with budgets the cap is a temp solution!
Username: Nd4spd18
Northwest PA
Post Number: 7495
Capacitors are not a solution for not having an HO alternator. As stated by others the alternator is the only source of power.
So yes, you are going to need a HO alt and a good battery to run 2000w of amplifiers.
Username: Ebin5446
GA
Post Number: 11
i was ignorant on this subject when i started installing my system and i was worried about my lights dimming so i went ahead and got a cap and guess what my light still dim i am on a really tight budget so i have to wait to get a ho alt but thats one of the things on my list of things i need get an ho alt it def is worth it
Username: Drant19
DUB-C, TX
Post Number: 954
see if you cant sell that cap to a friend or something. i did the same thing, it didnt help my car at all. only bought it cuz the guys at BestBuy said it would solve my dimming problems. we are all noobs at one point. just learn from this and try to sell that cap to someone who doesnt know lol
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Help.Ho atlernator? [ « Previous ] [ Next » ]
