Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Hifonics ZXi 1006 powering focal 165 kf
Author Thread: Hifonics ZXi 1006 powering focal 165 kf
Username: Creedom503
would a Hifonics ZXi 1006 amp be a good match for the focal 165 kf components?
the amp is rated at 250rms x 2 @4ohm
and the speakers are rated at 80watts rms
and 160watt peak power
is this amp too much power should i be looking into the Hifonics ZXi 6006 which is rated at 150watts rms x 2 @ 4ohm
any comments would be appreciated
Chris
Username: N2audio
Lawrence, Ks
Post Number: 1546
an amp with ample power is rarely a bad thing. The 1006 is probably not actually 250x2, but not too far off. A conservative gain setting should keep your speakers safe and really bring them to life.
However, I think the 6006 should still have plenty of power to bring the best, or close to the best out of those speakers.
I think the 6006 is plenty, but if the 1006 isn't much more expensive I'd probably go that route. From what I can find - considering cost it looks like the 6006 would be the logical choice.
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Hifonics ZXi 1006 powering focal 165 kf [ « Previous ] [ Next » ]
