Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > 1 2000 watt hifonics brutus or 2 1000...
Author Thread: 1 2000 watt hifonics brutus or 2 1000watt JL audio amps
Username: Me123456
i need some help im getting two JL w7's i want to know should i get two JL audio 1000watts amps or can i get one 2000 watts hifonics brutus amp and still sound just as good? the w7 have 1000watt RMS and 1.5 ohms
Relevant Product Info
Username: N2audio
Lawrence, Ks
Post Number: 1544
Are you looking at the HF bxi2006 or 2008?
Aren't the 8-12 w7's all 3 ohm subs (13 @ dvc 1.5)? By 1.5 are you already assuming parallel wiring for a total impedance of 1.5 ohms?
For the past several years the Hifonics amps have been testing at a little less than rated power, so until there's evidence proving otherwise that's a safe assumption IMO.
So being rated at 2000w at 1 ohm, and 1300 at 2 ohms that would amount to 1650 (rated) at 1.5 ohms. Which means 1200-1400 actual. That's plenty of power to get a pair of w7's sounding very good, but the pair of JL's at an under rated 1000w each will get you slightly more output. It would be a measurable difference, but not a significance to the ear.
The bigger HF's -- 2608 and 2706 will get your roughly the same output as the two JL's.
Sound quality really isn't an issue.
Username: Drant19
DUB-C, TX
Post Number: 829
if you got the money to spend on 2 JL 1000/1's then why are you looking at hifonics?
JL over Hifonics ANYDAY,EVERYDAY!
Username: N2audio
Lawrence, Ks
Post Number: 1551
In general quality and prestige, sure, but at <$500 for a bxi2608d vs 1200-1500 for the JL's I find it hard to justify the money. Unless you have a ton of it, OR this is a show-type setup or you plan to have it for MANY years.
Username: Me123456
the specs say the Nominal Impedance for the w7 is dual 1.5 ohms thats what i was going off of and i plan on having it for a while not just for show. i have the money to get either but if i can save money by gettin just one hifoincs i was goona do that but i do rather get the 2 JL's and rather they be a little under powered then over powered so should i just get the two JL's?
Username: Me123456
i was lookin at the bxi 2008
Username: Treez
Its not loud til it he...
Post Number: 344
Dude! u bought yourself some great subs, likewise get yourself some quality amps.
Get the slash 1's...
You would not be disappointed....
Username: Ctmike
Ct.
Post Number: 6027
screw both those amps and go with a pair of alpine pdx1000.1s':-)
Username: Chaunb3400
All he does is catch t..., Alabama
U.S.
Post Number: 14204
2nd on the pdx's
pdx>PG Xenons>JL Slash
Username: Treez
Post Number: 346
i would assume that chauncey's last post ranks the amps in terms of their overall price, size and efficiency...
Username: Msand951
Riverside, Ca
Usa
Post Number: 69
i have a hifonics brutus 2006d model. i want to sell for 200 if interested im in riverside ca area.
Username: 420alldaylong
Post Number: 3535
http://www.theautosoundsuperstore.com/alpinepdx-11000.html
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5310
ctmike you read my mind LOL
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > 1 2000 watt hifonics brutus or 2 1000... [ « Previous ] [ Next » ]
