Home > Message Board > Car Audio > Head Units > No Power at Factory Harness
Author Thread: No Power at Factory Harness
Username: Lisajory
AB
I need help!! I am trying to install a new deck into my '07 Jeep Grand Cherokee. I have power at the fuse box which is fine but no power at the factory harness... HELP!}
Relevant Product Info
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1154
you have to wire your own, there is no positive wired for a after market on newer gms, 2000 and up need a external positive wire wired in just make sure when you wire up your acc you get 12 volts when the keys on and o with the key off. then wire your normal 12 volt source. after that you should be all good.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Head Units > No Power at Factory Harness [ « Previous ] [ Next » ]
